has my engine went out???
Old Dec 31, 2008 | 04:48 PM
CLCAMARO305's Avatar
Car: 1990 Camaro Rs
Engine: 350 Carb
Axle/Gears: shetty
has my transmission went out???
i was driving around today doing some burnouts and stuff and then i went to drive to my buddies and when it went to shift into 3rd it just started reving instead of shifting....i think my tranny went out
and if it has gone out any websites with good reliable tranny for cheap (under $700)
Old Dec 31, 2008 | 07:57 PM
Shagwell's Avatar
Car: projects.......
Re: has my engine went out???
Sounds like you've hurt the 3-4 clutch pack, which is the most comon failure in a stock 700r4. - You may be lucky enough to find that you heated the fluid enough that it will hold again after cool down, though it may not last long. If it holds after cooling down, change the filter and fluid, keep your finger's crossed and save up some more money. $700 won't buy a good 700r4, not even what I'd consider a decent stock rebuild.
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
