speedo drive gear missing?
Old Dec 31, 2008 | 01:18 PM
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
hi, I have an 89 camaro w/ a T5 and have had some trouble w/ the speedo since owning the car. I put a new speedo cable in because the old one was pretty much destroyed, but that didn't fix it. I reached my finger into the housing to feel if the drive gear was locked up or not, but its simply not there. Is this a common occurance? I know I have to remove the tailshaft to get to it, but what could have broke to make this happen? how much do these cost and are they very easy to install? any input would be appriciated.
thank you
Old Dec 31, 2008 | 05:53 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: speedo drive gear missing?
Originally Posted by chevyracingrox
but its simply not there. Is this a common occurance? how much do these cost and are they very easy to install?
Never heard of that happening under normal driving circumstances. Not costly. More difficult to install. Check the following link (which is also a sticky):
https://www.thirdgen.org/forums/tran...ve-driven.html
JamesC
Old Dec 31, 2008 | 08:27 PM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
Before I swapped my T56 in I had two speedometer cables break with my T5. Was the bottom cables both times that broke, and both were caused by a bad upper cable. I didn't realize this was what was happening the first time unfortunately. The last time the cable seized up and locked the driven gear from turning. The gears work like a thread on a bolt. You stop the driven gear and the drive gear just threaded itself forward on the output shaft since there is only a little clip holding it in place. Had to pull the trans to get the gear back in place. Was a real pain just to fix my speedometer. I replaced my two part cable with a new 1 piece unit from a parts store. Works great and cost about $12 as I recall.
This may be what happened to you. Unfortunately you will have to get the tail housing off to see what's going on in there. Good luck.
Old Jan 1, 2009 | 09:33 AM
that sounds like it might be what happened. my speedo cable is the same length as stock, but its 1 piece. I KNOW its seated on the speedo guage right so I was wondering why it wasn't working. I took off the driven gear on the tranny to see if I could get it in farther thinking its just not in far enough. thats when I came across this.
I think I'm gonna take the tail shaft off today. I'll post pics if I do.
Old Jan 1, 2009 | 02:59 PM
JamesC
thanks for the link, its really helping a lot.
got everything taken apart, my speedo drive gear was in place and doesn't look torn up at all! I'm going to look more at the fitment of the speedo gears. anyone have an idea why this thing is doing this to me?
Old Jan 1, 2009 | 06:31 PM
got some pics up
Attached Thumbnails speedo drive gear missing?-trannywork-006.jpg   speedo drive gear missing?-trannywork-007.jpg   speedo drive gear missing?-trannywork-008.jpg
hectre13
Dec 11, 2023 08:14 AM
Jorlain
Aug 24, 2022 05:11 PM
jklein337
Sep 19, 2018 06:23 PM
86White_T/A305
Aug 17, 2015 12:16 AM
beachrodder
Aug 7, 2015 04:27 PM
