Need help w/ Flywheel removal
Old Apr 10, 2001 | 11:13 AM
84TransAm's Avatar
I've tried loosening the flywheel bolts, but every time the Flywheel keeps turning. What do I need to keep this thing in one place so I can take the bolts off? And how tight would they be torqued in?
--Steve S--
1984 Trans Am 305 LG4, 5 speed
Daily Driver, Flowmaster 80 Series
Holley 600 cfm & vacuum advance
Old Apr 10, 2001 | 11:37 AM
KS91Z28's Avatar
Smacking the wrench with a hammer is usually enough for me to break the bolts loose without the flywheel moving too much. Other times I have had to get someone else to hold a large screwdriver against the teeth of the flywheel and the edge of the tranny. (probably not too good on the flywheel teeth)
Old Apr 10, 2001 | 12:59 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
It won't hurt the flywheel teeth at all. There is a Lisle tool made to do that very thing. The shock your starter gives it each time you turn it over is much more severe than what you'll do loosening or tightening the flywheel bolts.
I just use a large flat-tip screwdriver. One hand on the breaker bar, the other on the screwdriver.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" Hedders, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere w/open diff & slipping tranny. Daily driver while Camaro was being put together.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Stangski09
Nov 14, 2015 01:27 PM
Stroopwafel
Sep 11, 2015 06:38 AM
Nick McCardle
Sep 10, 2015 08:36 PM
