ID this Trans...
Old Jan 3, 2009 | 07:07 AM
Demon355's Avatar
ID this Trans...
Dude says its a WC but I just want clarification. ID # is 13-52-065-914. Any thoughts? Thanks.
Old Jan 3, 2009 | 07:17 AM
Stippy17's Avatar
Car: 1986 Trans Am, 1985 Trans Am
Engine: 400 SBC, H.O. 305
Transmission: TH400, 700R4
Axle/Gears: 10 Bolt/3.73s, 10 Bolt/3.73s
Re: ID this Trans...
Look at the counter shaft bearing at the front of the case. If it has 'Timkin' on it then it is a WC trans. This same bearing will have a shallower center, whereas a non-WC will have a flat face on the bearing.
Looking up that number Im getting that it is infact a WC Tranny.
Old Jan 3, 2009 | 07:19 AM
Demon355's Avatar
I was told it was a WC and it came out of an IROC. I don't have the trans yet nor do I have pictures so I figured I'd post the ID # and see what people would say. If I had the trans/pics, I could tell myself by looking at the bearing casing you mentioned. Thanks.
Old Jan 3, 2009 | 07:24 AM
Stippy17's Avatar
Do you know what year Iroc it came out of?
Old Jan 3, 2009 | 08:31 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Check the sticky at the top of the page for more info.
JamesC
Old Jan 3, 2009 | 04:04 PM
Demon355's Avatar
I've run the number but only came up with 'Mustang/Capri" etc. Talking with the current owner, it came out of an '88 IROC. I'm not 100% sure on the first year for WC T5's but he and the website both claim it's a WC.
Old Jan 3, 2009 | 04:13 PM
JamesC's Avatar
You haven't checked the sticky, have you?
JamesC
Old Jan 3, 2009 | 04:20 PM
Demon355's Avatar
I have yes. I'm waiting on pics to get the code for the ratio's in the trans.
Old Jan 3, 2009 | 05:00 PM
Stippy17's Avatar
85' is when WC Tranny's were introduced. Yeah the best way to identify it is when you have pics to look at it. The casing could honestly be from any car that had a T5 if it was ever rebuilt.
Old Jan 3, 2009 | 06:23 PM
JamesC's Avatar
You should check the sticky.
JamesC
Old Jan 3, 2009 | 06:35 PM
Stippy17's Avatar
"World-class T5's were used in various Ford models starting in the 1985 model year, and in various GM models starting in the 1988 model year."
I apologize..I was wrong.
Old Jan 6, 2009 | 07:11 PM
Pat Hall's Avatar
That ID # in your first post looks to me like the casting # for either the extension housing or the main case of the trans. He needs to give you the model #, which is located on a metal tag that's attached to one of the tailshaft housing bolts. For example, the model # for a WC T5 out of an 88 305 TPI car would be 1352-176. It's way common for people to give out the case or tailshaft casting #, thinking it's the model #. Another place you can commonly find the model # is the decal located on the top cover of the trans. On the NWC T5's it's usualy a green and white sticker, while the WC ones usually have just a plain white sticker. The model # is in large text on the green and white stickers, while it's really small on the white stickers.
MrDude_1
FAQ Board
436
Feb 6, 2017 08:47 PM
ZAKS62
Jan 9, 2008 08:15 AM
ZAKS62
Exterior Parts for Sale
Jan 2, 2008 10:28 AM
ZAKS62
Dec 14, 2007 10:04 AM
RS91
Jul 29, 2001 10:23 PM
