Need help identifying rear in GTA
Old Jan 5, 2009 | 07:58 PM
1970 Buick's Avatar
Car: 1989 GTA
I need to figure out what rear is in my 1989 GTA 350 auto w/ four wheel disc brakes. Is it a Posi unit? It is the 10 bolt housing, not the BW 9 bolt style. Can you tell me any information on this, all is greatly appreciated!
Old Jan 5, 2009 | 08:31 PM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
Re: Need help identifying rear in GTA
Easiest way would be to look under for the "Limited Slip Additive" tag bolted to the rear cover.
If not rotate one rear wheel and see if it turns the same way, if it turns opposite it is non posi.
Old Jan 5, 2009 | 10:07 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
All the 1989 GTA's came with a 9 bolt. If you have a 10 bolt then it's not original or it's not a real GTA. The only way to know what's inside the diff is to take the cover off and have a look.
The 350 GTA came with a 3.27 9 bolt.
Old Jan 6, 2009 | 01:08 AM
1985WS6TA's Avatar
Car: 1985 WS6 Trans Am T-Top
Engine: 355 TPI N/A
Transmission: Borg/Warner T-5
Axle/Gears: 3:42
Yeah chances are you have a Borg Warner 9 Bolt with 3:27's.
You can also check on the side of the case near the pinion, it should say Borg Warner.
LilHot
South Central
Apr 13, 2026 11:46 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
LilHot
Exterior Parts for Sale
20
Apr 1, 2016 04:45 PM
LilHot
Aug 19, 2015 10:02 AM
Street Lethal
Aug 14, 2015 08:25 PM
