need help on putting tranny back in... please !
Old Apr 15, 2001 | 12:53 AM
91camaroRS's Avatar
i am going insane trying to put the 700r4 back in my car.... ok heres the situation i put a 350 in my camaro now i put on the flywheel and the converter.. now the problem is putting the tranny back in it is impossible to line back up like the shaft and the converter... im thinking about taking the converter off and putting it on the tranny then raising it to the engine and bolting it on...any suggestion or maybe taking the motor out again and putting the tranny back on cause i can NOT put it back on the way it is now.. maybe im doing it wrong..i dunno .. i need help please !
Old Apr 15, 2001 | 02:16 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The converter has to be put on the transmission before lifting it in. Be careful not to let it slip off the shaft while you're lifting or the seals will probably get torn.
Old Apr 15, 2001 | 09:01 AM
ede's Avatar
ede
yeah there is no way you'll ever get the convertyer to line up without taking it off the flex plate.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Apr 16, 2001 | 03:58 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
MAKE SURE THE CONVERTOR IS FULLY SEATED!
When you have the bellhousings mating together (trans & engine), with a few hand-tightened bolts holding them together, make sure your convertor's seated. You should be able to slide the torque convertor forward/back along the input spline of the transmission, while the trans is bolted to the engine. So, this means you (1) removed the TC from the engine flywheel and put it onto the input shaft of the trans (lube that area of the TC with some trans fluid), (2) have a few trans-to-engine bolts screwed in hand-tight, and (3) didn't have the torque convertor bolted to the flexplate.
If the torque convertor is mashed hard against the flywheel, STOP! You didn't seat the TC all the way into the trans. There's an extra set of splines on the tranny's input shaft that you have to catch in the torque convertor. This is because the 700r4 uses lockup TC's. Unbolt the trans from the engine, slide it back, and spin the TC until it catches the second set of splines.
Remember; before you bolt the TC to the flexplate, the TC should be able to slide towards/away from the flexplate. Otherwise, you'll damage the TC and trans in one twist of the ignition key!
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
[This message has been edited by TomP (edited April 16, 2001).]
camaro11j
Sep 19, 2018 08:49 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
drathaar907
Aug 6, 2015 04:20 PM
