Rear-end gurus...need help.
Old Apr 15, 2001 | 03:17 PM
IROCracer's Avatar
My BW 2.77 9 bolt went out a while back and I bought a rear off the classifieds here. It's a 10 bolt 3.73 with rear discs. MY brother has the car right now and he had some of the mechanics where he works help put it in (he's got mechanical aptitude, but he's not that smart when it comes to tech). Anyway, he swears up and down that the rear isn't POSI. The guy I bought it from said it was off an 85 IROC (sounded right to me), but I could swear all rear disc 3.73 rear ends were POSI....the numbers are rusted away...tried scrubbing and everything...they're gone.
KElly
If you've gotta fix it, fix it better than stock.
Old Apr 15, 2001 | 05:23 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
you will need to open it up. then look inside the carrier hole if it is just 4 gears with no springs or lever stuff than it is just an open rear the posi rears have springs and or levers It is just that simple
Old Apr 15, 2001 | 06:59 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
hold one axle still,if you can turn the other axle its not a posi or its a posi that needs rebuilt
Old Apr 15, 2001 | 07:58 PM
OLDYELLR's Avatar
Car: '85 IROC
If it's from an '85 it could be an Eaton Locker (Guvlock) limited slip. A 3.73 limited slip would have the code "8PS" on the front of the right axle tube. An open 3.73 would be "8JB" or "8KD". These Eatons act like an open diff when up on jack stands, until you spin one wheel at about 100 rpm or more and then the clutches engage and the other wheel stops spinning backwards.
1985 Yellow IROC-Z 5.0 HO, T-5 3.73 Torsen, 4 wheel disks
PFCM pads, GTA wheels, Koni yellows, B&M Ripper, Dynomax
Old Apr 15, 2001 | 09:07 PM
Engine: ls1, LB9
like I said open and check thats the only proven way
Old Apr 15, 2001 | 09:29 PM
82camaro's Avatar
Car: 82 camaro SC
If it's posi, it's probably worn out anyway.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old Apr 16, 2001 | 06:11 PM
ede's Avatar
ede
yep the only sure way is to pull the cover and take a look. doesn't hurt to do a little inspection and change the lube and additive.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Elephantismo
Feb 13, 2019 12:51 AM
Quzyle
Oct 15, 2015 03:35 PM
Numbah-1
Oct 2, 2015 08:27 AM
Jonas Earl
Sep 27, 2015 07:39 AM
TexasMaro
Sep 15, 2015 06:50 PM
