TV cable adjustment woes
Old Apr 14, 2001 | 12:53 PM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
I just got done adjusting the TV cable on my TBI equipped '88 Camaro. It was waiting a real long time to shift from 1st to 2nd and when it did shift it was hard enough to snap your neck. I decided that the TV cable was probably out of adjustment so I adjusted it as described in the Haynes manual. Now the TV cable is too short and won't allow the throttle to open all the way. Should I depress the adjustment tab and go the other way with it? Is there some other problem that needs to be addressed?
-Mark W.
'88 SC Camaro w/ 305 TBI
Old Apr 14, 2001 | 04:32 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
U adjusted it and it won't go to WOT?? Are u sure u did it right, did u hear it ratchet??
Old Apr 14, 2001 | 06:39 PM
CamaroZ_85's Avatar
I always have problems w/ the TV cable. I found that the "textbook" way isnt really good. Try this...push the tab in, and pull the adjuster all the way out. You should have slack in the cable. With the throttle closed, push the tab in and slide the adjuster in just enough to remove the slack. Take it for a test drive. Start off w/ normal throttle, and just after it shifts into 2nd, nail the gas and it should downshift back into first. If it doesnt do this, slide the adjuster back towards the firewall 1 notch, and test it again, until you get the upshift back into 1st gear. hope this helps....
350, Comp 262, Edelbrock Performer intake 600 cfm carb and exhaust, headers
-JVC, Eclipse, Pioneer, MTX, Phoenix Gold, Planet Audio
Old Apr 14, 2001 | 06:44 PM
Mark305TBI's Avatar
I just pressed down the adjustment tab and opened the throttle to WOT. Now it seems to be properly adjusted. No more broken necks and chirping tires on the 1-2 shift.
-Mark W.
Old Apr 17, 2001 | 11:40 PM
Keith5's Avatar
Car: C1500
You're suppossed to push it to wide open throttle when adjusting it, that's how it adjusts.
Old Apr 18, 2001 | 09:51 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yeah; if you have the adjuster tab pressed in and you just open the throttle to WOT, the TV cable will pull out further than it should...
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
88SS6SPEED
Nov 11, 2015 07:05 AM
WejaZ28
Oct 3, 2015 07:38 PM
corey8084
Brakes
Sep 15, 2015 08:14 PM
SG91camaro
Sep 5, 2015 10:27 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
