transmission? I NEED HELP!!!
I have a 92 firebird V6 3.1L, and it was running fine. but one day i had to take my girlfriend to work and i didn't want to go fast. the rpm was going up but my mph wasn't goin anywhere. it wouldn't go past 40. and you could it rev, but not do anything. some people said it's the transmission, but other say it's just the transmission filter and to change the fluid. any other advice? it would be greatly appreciated.
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Re: transmission? I NEED HELP!!!
Try changing the fluid and filter.. Is the fluid dark when you remove the dipstick?
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Does it smell "Burnt" smell the dipstick and see. If it is really dark, then you are probably going to need a rebuild (Frictions are probably gone)
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
Take this as a lesson. Change your tranny fluid and filter every 35,000 miles. I don't care what the owners manual says, change it anyways. Anytime you buy a used car, change it, because it's most likely never been done.
Car: 64chevelle/smokey trans am
Engine: 350 p600 pro charger/350
Transmission: 350/700r4
Axle/Gears: 3.36
t.v. cable may have come disconnected. governor gear plastic may have apple cored or broke off, t.v. valve may be stuck(not to be confused with plunger), and or shot at and missed **it at and hit.
Car: 1988 Z28 Camaro
Engine: TPI 350
Transmission: TH350
Axle/Gears: 3.73 10 bolt
Maybe the torque converter is warn out. and for sure on the oil change and filter all the time. good luck
I change mine every 6 months. The car only gets driven about 2500 miles a year and someone once told me that tranny fluid absorbs moisture... Better safe than sorry... Good luck, and let us know how it turns out.
thanks guys, i couldn't go out and check it today. we just got 13in. of snow. im going to shovel it off tomorrow morning and see what's cooking. i'm also taking it up to my school whenever it opens back up (school closed because of the snow)
Well I know I haven't been posting in a long time. Well come to find out I needed a new transmission. So I found this little shop where they were selling my transmission for only $200!!! So of course I grabbed it right away. And it's currently in the shop getting the transmission installed. Thanks for the input.
Axle/Gears: 3.36
I was correct? Shot at and missed, **it at and hit. You could probably sell your old core and recoup the cost of the new?,Used?,rebuilt?, transmission.
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
TX-SleeperC5
Sep 24, 2015 03:13 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
