hydraulic clutch bleeding
Car: 92 & 91 Z28 1LEs, 87 IROC-Z, 90 ZR1
Engine: L98, LT5
Transmission: 700R4, 6-speed
Axle/Gears: 3.45, 3.42, 3.73, 3.27
I just bought a new clutch master and slave cylinder for my Camaro and I cannot seem to get all of the air out of the system. It has enough pressure to move the clutch fork a little bit but not enough to disengage the clutch. I know GM sells a pre-bled system, but I would like to see if I can get this to work first. Are there any tricks of the trade to bleed these? Thanks, Erik
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
It should bleed just like normal brakes do. I just made sure the res. was full had my freind push the pedal as I opened and closed the bleeder as if it were a caliper. also make sure it is not striped it happens to the best of us.
