3.73 or 4.10 with t56
Old Apr 18, 2001 | 11:58 PM
AustinT's Avatar
Id like to hear from some people who have done the swap. I have a t56 and a 3.08 right now and I have to ride the clutch. Should I go with the 3.73's or should I go with some 4.10's. I have a HD Zexel Posi So i should be able to keep decent traction. My motor is a zz430 with the Hotcam, Holley 750 Vaccumm secondary Carb. I have some new 3.73's richmond gears sitting here in a box but I could Always sell them and get 4.10's
Old Apr 19, 2001 | 02:03 AM
BOWTIROC's Avatar
From: Coulterville, IL...Currently on Beale AFB, CA
I think the 4.10 would be the way to go. I have 3.70's and have to go through the lights in 3rd
Black 89 IROC...Mods: 355, 10.5:1 comp, Big Solid Crower Cam, TFS heads, Victor Jr, Holley, and a 5 spd...12.72@ 116.9 with a 2.16 60ft time on BFG radial TA's
Old Apr 19, 2001 | 10:07 AM
Tadder's Avatar
I would go with the 4.10 gear set. I put that in my rear with a t-5 tranny and loved the difference it made. I have a mechanical speedo and it threw the mph way off. I found a guy that hooked me with a box that screws onto the tranny and the cable screws into it. Fixed my problem. The speedo is correct now.
Old Apr 19, 2001 | 10:18 AM
Mark W. Winning's Avatar
I have 3.73's with the t-56. With a 26" tall tire, I go through the traps in 3rd gear also. 4.10's would be the way to go, I will be upgrading soon. Plus, while cruising around town six gear is pretty much usless.
1992 Pontiac Firebird 350/Six Speed
1987 Toyota Pickup 383/500+ HP
Old Apr 19, 2001 | 10:22 AM
raging86's Avatar
can you guys hook up with 4.10gears in 1st gear? when i do my swap i was thinking about swappin gears but have heard guys say that first gear was worthless with rear gears that low.
86 IROCZ
T-Tops
700R4
305 TPI
3.23 gears
shift kit, manual TC switch, manual fan switch, flowmaster exhaust with edelbrock TES headers& hollow cat, gutted MAF.
Old Apr 19, 2001 | 02:04 PM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
If I were doing it (which I will be in a couple of months) I would definately go with the 4.10's. Because that gear has a good cruise RPM in a 5-speed and then with another gear forget about. thats it go with
5.10's!!!! j/k
I WOULD RATHER PUSH A CAMARO THAN DRIVE AN IMPORT
1983Z28 350w/ edelbrock performer RPM power package with 64cc aluminum heads, dynomax shorty headers, 700R-4 with shift kit, 750cfm carb, edelbrock 3" exhaust system, ASCD SS hood, 16" IROC rims.
future mods:
completely done over suspension, black paint with flames, Hurst shifter, dakota digital gauge package, procharger supercharger.
Old Apr 19, 2001 | 09:14 PM
AustinT's Avatar
The richmond 4.10's are on the way. Thanks for so many replies and responding so fast. I had a 10% off coupon that ran out tomorrow so I orderd today. The guy at summit said, On his computer he had a note that some Torsen Posi carriers had to have some light grinding done on them. And some had to use c clip eliminators. Any idea what he was talking about. I hope I dont have to grind on the Posi. I dont know why I would have to use c eliminators. I have Axles from drivetrain direct and they fit just fine.
Old Apr 19, 2001 | 11:04 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
It should fit. any steeper gears would need the two peice pin but, I know from pulling 4.11 gears from an s-10 that the pin barely misses the ring gears teeth pulling it out. but, does miss.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bigjay89gta
Oct 15, 2015 08:04 AM
meeklay812
Oct 1, 2015 03:46 PM
Vincent135
Sep 28, 2015 10:50 PM
JSDaddy189
Sep 26, 2015 03:50 PM
