can some1 xplain thebest way to put the vette servo..
i just got one but i heard that there is a special tool to get the c ring out.. or what can i use to get it out.. also is it pretty self explainitory how to put the new one in.. also what can i expect when i get the new one in.. also should i change the tranny filter while i am down there.. thanks for the help..
1988 firebird ws6 formula350tpi ascd ram air hood GT AUTO 4th gen spoiler black paint with blue pearl centerline champ 500 16x8 all around potenza 245 50 16 on front and 27x11.5 16 mickey thompson sportsman pros on the rear(real sticky!!) msd 6al box blaster 3 coil accel 8.8 race wires hooker shorty headers hooker cat back system pro shift light A pillar gauge pod and water temp and air/fuel ratio gauges autometer oil pressure gauge b&m mega console shifter vette servo custom ram air system with a 9" K&N cone filter tb coolant bypass slp runners polished plenum and runners 170* thermostat smog pump and a/c delete plus cat delete march underdrive pullies, tpis airfoil cvr high torque starter (love it) aluminum drive shaft
best 1/4 mile run of 14.44@ 96.53
this run is before the new exhaust system new sticky tires coolant by pass smog removal new runners new thermostat and new three core radiator since i would get to the line and be well over 220* aluminum drive shaft and vette servo
You will need a scribe (scriber) to get to the seal, get underneath & pull down, then cut it & pull one side down, it will unravel. Remove the old servo and replace with the Corvette servo and new O-rings in reverse order, done.
Glad Too Help!!!
Glad Too Help!!!
