2.73 gears
Car: 1991 Trans Am
Engine: 305tbi to 350 carb'd
Axle/Gears: Stock
2.73 gears
is it possible to have both tires spin by having 2.73gears at all???
Car: 86 Camaro iroc-z28
Axle/Gears: 3.42 Posi
Re: 2.73 gears
having both tires spin has nothing to do with the gears, it has to do with the whole differential itself, whether its a limited slip or an open diff. open diff will give you those one wheel peels, while the limited slip will give you a burnout with both wheels spinning if its not too worn out. all this plus take into account whether your engine is strong enough to spin both tires.
Car: 1991 Trans Am
Axle/Gears: Stock
Re: 2.73 gears
ah ok cool i always dropped it to 1st to do a burnout never kept it in OD maybe thats y but if i take off left the left will spin with the right but if i turn right just the right will spin. thanks for the reply though
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Re: 2.73 gears
yup thats how the open rear works, you can spin the tires but you have to put alot into it and in the end you come out with 1 bald tire lol
Car: 1991 Trans Am
Axle/Gears: Stock
Re: 2.73 gears
but if i keep it in od with this new 350(when its ready to drop in) it should be able to spin both tires then right?? thanks
Car: 1992 Camaro
Engine: 350 .030 over 298 cam 9.1 Flat tops
Transmission: T5 swap complete
Axle/Gears: 3.73 posi the 4.10s are history
Re: 2.73 gears
The engine has nothing to do with having both wheels spin what so ever, its all in the carrier in the rear end. You can have 1000hp and you could not spin both tires with an open diff...
Car: 1987 Camaro IROC-Z28
Engine: TPI 350ci L98
Transmission: T56 - Hurst Shifter
Axle/Gears: BW - 3.70
Re: 2.73 gears
It also has nothing to do with the transmission or the gear that you put the transmission into.
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Re: 2.73 gears
The tires spinning has to do with the rear differential,(not perfect explanation but this should help) open carriers are designed to transfer the power to the wheel with traction, where as a LSD is made to evenly transfer the power to both wheels, which is why they both break loose instead of the one wheel fire you have going on now
Re: 2.73 gears
Well he said he had an automatic transmission. So it doesn't matter if the shifter is put in 1st 2nd Drive or OD. If you are at a dead stop it's always going to be in 1st gear regardless of whether the stick is in 2nd Drive or OD.
With a manual transmission that's another story but that's not what he has.
Car: 1991 Trans Am
Axle/Gears: Stock
Re: 2.73 gears
yeah but if i sit there in OD it will shift from 1 to 2 wouldnt it?? and when it does then they both should start spining becaues iv seen vids of both tires spining on a camaro with a 700r4 (stock) right???
Car: 93 Formula,88 T/A,01 WS6
Engine: 93 LT1,88TPI305,01 LS1
Transmission: 93 700R4,88 700R4,01 T56
Axle/Gears: 93 3:73's,88 3:42,01 3:40
Re: 2.73 gears
Hold the break, Hold the gas you can possibly spin both tires but when you let off the break your gonna let loose with the old one wheel smoke bomb. And this CAN but will not ALWAYS (Most likely wont)happen
With an open diff that is
Last edited by 1brd2brd3brd4; Jan 20, 2009 at 04:31 PM. Reason: Automerged Doublepost
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Re: 2.73 gears
i can spin both tires in first and second holding on the brakes..... can also lay rubber going into 2nd and 3rd with a 700r4 and a mildly moddified 305TBI, before i had the LSD it did it with one tire, the only way you may bet both to burn with an open diff, (i dont care what gears or motor you have) is with a line lock.
in other words get a LSD and while you are at it get some better gears to
and yea you can see a stock 700r4 do twin tire fire, if it has a LSD from the factory
Car: 1991 Trans Am
Axle/Gears: Stock
Re: 2.73 gears
yeah i have limited slip so should i keep mine in od and try it because i havent tryed that yet???
Re: 2.73 gears
LSD= Limited Slip Differential.And no....you dont need a line lock to spin both rear wheel with an open diff. It can happen though 9 1/2 times out of ten it will not spin both tires
Re: 2.73 gears
Ya'll type too fast...LOL
Only car I ever drove I couldnt make spin was my sisters datsun B 210..... Rev it to 6 grand, drop the clutch and blaaaaaaaaaaaaaaaaaa. Not even a squeak
Last edited by 1brd2brd3brd4; Jan 20, 2009 at 05:30 PM. Reason: Automerged Doublepost
Re: 2.73 gears
You want to do a burn out or you want to spin from a dead stop while taking off?
Re: 2.73 gears
Burn out should be eazy. Hold left foot on break......put right foot to floor
Off the line spin your gonna need gears
Last edited by 1brd2brd3brd4; Jan 20, 2009 at 05:38 PM. Reason: Automerged Doublepost
Re: 2.73 gears
spin off the line with 2.73.............mash it to the floor
trust me it will burn out with a 305 TBI, you just got to free up to HP in it.....i could never hook up with my stock suspenion and 2.73's open
trust me it will burn out with a 305 TBI, you just got to free up to HP in it.....i could never hook up with my stock suspenion and 2.73's open Joined: Nov 2005
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Re: 2.73 gears
You will need a limted slip (posi track) if you want to do that.
You stated that you already have "LSD", I doubt that you have it, being a 91 305 TBI with a 700R4, your car came with a 2.73 open rear. And the fact that you stated you only do one wheeled peels.
Car: 86' Z28
Axle/Gears: 2.73 (for now)
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Re: 2.73 gears
thank you for the insight on that one kris lol
blkfirebird; if you want to check, i suggest you pop the diff open and take a look and you can change that fluid that probably hasnt been touched/checked in years
Car: 1988 Camaro Sport Coupe
Engine: 5.0 305 Carb'd
Re: 2.73 gears
hey how much does an LSD usually go for? we'll say a used one out of parts car camaro or something.
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Re: 2.73 gears
OR there is the Zexel torsen out of the 4th gens, drops right in , just need to be sure to have 28 spline axels. Worth it in the long run IMO because the 28 spline axles need to hold up to the brute force
Car: 1991 Trans Am
Axle/Gears: Stock
Re: 2.73 gears
ok ill do that but what would that do for me though?? ill do it today and should i put that Lucas rear end oil in it??? thanks
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Re: 2.73 gears
one, inspect the spider gears for chips/cracks and 2 take a picture of it, post it up and then we can tell you if its LSD or not.
Car: 1991 Trans Am
Axle/Gears: Stock
Re: 2.73 gears
just a FYI, the carrier in a open diff, when you look through the "window" on it you will just see spider gears and a shaft going through the center where the axles meet...... a LSD will have springs in it and clutchs that you can see.
Re: 2.73 gears
I usually sell a limited slip for about $100...............need one?
Re: 2.73 gears
http://rides.webshots.com/album/55410292AnMJrE
Look through these and see if yours looks like one of them.
Car: 1991 Trans Am
Axle/Gears: Stock
Re: 2.73 gears
ok so when i do this with the cover when i put it back on i need a new gasket? also when i fill it back up i fill it to when i can feel it when i stick my finger in the hole?
Re: 2.73 gears
You may want to get a service manual to help you with some of the basic stuff.
Re: 2.73 gears
These cars can do very good burnouts.
The reason your not getting both tires to spin is either you have an open diff, in which case they can both spin, but not really likely. Or your LSD is worn out.
If you think you have a LSD look at the RPO codes. The gears will be a GU then a number if I remeber correctly. That is the gear ratio that you already know. What you are looking for is G80. If it has that you have a LSD, if not you have an open diff.
Little something to see what it can do. This is my car with a stock 305, TBI, 3.08's, and the factory LSD. Keep in mind this was at a track not on a street. It was also 2nd gear, at about 6,000 RPM.
UltRoadWarrior9
Sep 2, 2015 08:24 PM
