Help.. Another TV Cable Question
Old Apr 22, 2001 | 03:16 PM
CAMARORS1991's Avatar
Ive been trying to adjust my tv cable at the throttle body with no luck. I know this is supposed to be easy but I guess Im an idiot. Ive looked at the tech article and I have the big camaro service manual. I see what Im supposed to do but I am unable to do it. I have a 91 RS tbi and I cant seem to find the metal reset table for the cable. I think I found it but when I try to push it in nothing happens. Any help would be appreciated.
Old Apr 22, 2001 | 03:19 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Not sure what tech article you are using, but try this one: TV Cable
After you push the "D" button, you will have to push the "slide" into the housing, it won't move by itself.
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Apr 22, 2001 | 03:44 PM
Thanks for the reply. That article explained it much better. I believe Ive got it adjusted properly. Thanks again.
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
redmaroz
Aug 16, 2015 11:40 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
