How much can the 700R4 take?
Old Apr 17, 2001 | 03:21 PM
89FormulaL98's Avatar
is the a built-up 700R4 ok at 10, 11 second 1/4 miles? or would a special racing trans be necessary?
Old Apr 18, 2001 | 07:34 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
There's a guy in this months chevy high performance mag who goes for top speed and runs a 700R4 behind a big block and makes 179mph charges. (No lightweight car either!!!)
Old Apr 21, 2001 | 02:18 AM
rkessel's Avatar
It depends on what you mean by "built up" a stock 700r4 is rated to take 370 foot-pounds of engine torque B&M rates theres 450, TPI rates theres at 500+ and I've heard that Houghes will go even higher. In any case, What kiils these tranys is heat, so if you are using it for performence get a good low restriction trans fluid cooler. The more power you have the better cooler you need. One word of caution, plumb the aux. cooler after the radiator cooler, it is possible to get the fluid too cold if you don't. The guy mentioned in the previous post was probably running a purpose built race car and may have had to rebuild that trany every few months. As far as making a 10 second car, I would not use the 700 for drag racing if you want it to last. You will have to rebuild it too ofen. If you don't mind that, it's great because it's got a steep first gear, otherwise, use a th400 or 350. If you are building a street rod, and don't try to run those 10 second ETs to often you will probably be ok.
Old Apr 21, 2001 | 05:54 AM
Pro Built Automatics's Avatar
I have several high 10 second and many 11 second 700R4's out there. Yes it does take some work to do this, but with the right combination of a (9.5" Vigilante or 10" Continental torque converter) and a 700R4 that is built correctly, then it is possible to get these results with some longevity.
Hope This Helps!!!
Old Apr 21, 2001 | 02:11 PM
sparks383iroc's Avatar
Car: Mullitt mobile :)
Engine: it's stock LOL
Transmission: 700rJunk
Axle/Gears: 2 much 4 street not enough for strip
Hey Pro Built,
I'm running a slightly modified 700r4 behind my 383 (mid to upper 400s in torque). I'm putting a wider 2-4 band in it in a couple of weeks. What other parts would you recommend I upgrade while in there.
Here are some of the things already modified to the tranny:
TCI manual valve body
Larger servo
Larger boost spring?? in pump
Added clutches
B&M Trans Cooler
Precision Industries 2000 Stall convertor
couple other things I think but can't remember
Had a 13 vane pump in it, but went back to the 10 vane.
Any suggestions would help.
Sparks a flyin'
1989 L98 IROCZ, Bored .030 over,400 Crank,Dart PRO 1 Heads 200cc intake,ZZ3/ZZ4 Cam,Crane 1.6 RR,Edelbrock 3860 Hiflo TPI Manifold, AS&M LTRs, Edelbrock 58MM TB, Ported Plenum, TCI Reverse Pat Man Valve Body, SVO 24# injectors,TCI Streetfight Stall Converter, 3.23 Gears on Auburn Pro Posi, Some Suspension Mods
Old Apr 21, 2001 | 02:16 PM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
the trans that i had installed a couple of weeks ago is rated to handle anything under a 454 block . im sure it would have no problems in a 11 sec car. keep in mind though is expensive to get that type of trans.
91 camaro RS
- 305 TBI
Mods: Performer TBI intake, 1" TBI spacer, K+N, jet fan switch ,160 thermo,Accel control module, Jet Stage 2 chip, edelbrock TES headers, Compleate 3" Flowmaster exhaust, Edelbrock springs, KYB struts and shocks, 700R4 built by TSI, SLP tq converter, b+m trans cooler
Soon to come .SLP Posi 323,Spohn LCA's and panhard bar,Ascd ram air hood, Z28 spoiler and grille,white guage faces.
Old Apr 22, 2001 | 05:13 AM
transfixleo's Avatar
Properly setup, 600HP.
Old Apr 22, 2001 | 02:05 PM
well, eventually when i get to the point where i need to start worring about the trans, i will probably just get a TH350 or 400
Old Apr 22, 2001 | 03:47 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
bah if you running under 500 horsepower i wouldnt worry about it. my stock 700R4 (DEAD STOCK) runs behind a heavilly modded 355 with around 400 Horsepower, maybe 375 now since i changed the cam. it pulls real hard, has 100K original miles on it, and i beat on it every other day. My 4-speed borg warner however, rated @ 600+ horsepower in my red Iroc Z-28 camaro with it's 355 pushing 525 Horsepower blew up yesterday. it only had 2K miles on, good thing its under warranty. i hope.... now im thinking about putting a 700R4 in that car!! they are great trannys, great for street, and highway too. just make sure your cam isnt too big, i know for a fact those overdrive trannys dont like 230+ duration or alot of overlap, it kicks them in and out of overdrive alot.
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
