TV Cable, I Can't Seem to Adjust it Right!!
Old Apr 22, 2001 | 09:03 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
OK, I pushed in on the metal button and pushed the black piece all the way against the holding bracket. I let go of the button and pulled to WOT and I only heard one click maybe if that. So I figured this was wrong and just pushed on the button to pull out the piece a couple more clicks. The car is still hesitating to shift, should I just go w/ the original way I did it w/ only one click.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER
EDELBROCK 600CFM CARB.
KN AIRFILTER
UNDERDRIVE PULLEY
ACCEL HEI DISTRIBUTOR
2:73 GEARS
Old Apr 22, 2001 | 09:13 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Yes, pulling the cable out any more will cause shifts to be early and soft.
Old Apr 22, 2001 | 09:17 PM
Car: 99 Formula
Axle/Gears: 342
You said anymore will cause shifts to be early, but right now with it several clicks out, if I floor it the car will shift at like 5500 rpm staying at that rpm for a couple seconds and then shifts.
88SS6SPEED
Nov 11, 2015 07:05 AM
WejaZ28
Oct 3, 2015 07:38 PM
corey8084
Brakes
Sep 15, 2015 08:14 PM
SG91camaro
Sep 5, 2015 10:27 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
