700R4 shift lock / ignition lock cable
Old Jan 15, 2009 | 12:13 PM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
hi i have a 1983 trans am with 700R4
i am trying to swap the stock t-handle shifter for a camaro round shifter
What kind of shift lock / ignition lock cables would it have 2 round ones or 1 round and 1 square?
Old Jan 15, 2009 | 03:18 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 700R4 shift lock / ignition lock cable
2 round or one round and one square what?
Old Jan 15, 2009 | 03:48 PM
KITT1983's Avatar
Would a 1983 pontiac trans am with a 700R4 transmission have 2 round or 1 round and 1 square shift lock/ignition lock cables
Old Jan 15, 2009 | 03:52 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It will only have one lock cable.
Old Jan 16, 2009 | 07:57 AM
Shagwell's Avatar
Car: projects.......
If the only reason you're doing this is to get a round style ***, why not just swap the *****?
Old Jan 16, 2009 | 08:04 AM
KITT1983's Avatar
no i just want the camaro round shifter assembly, the 82 T/A **** is incompatible with the 83 T/A t handle 700R4 shifter (requires cutting and duct tape) compatible with the 83-86 camaro shifter
Old Jan 16, 2009 | 08:12 AM
KITT1983's Avatar
does it have two cables either 2 round or 1 round and 1 square
can someone just answer the question and stay on topic
Old Jan 16, 2009 | 11:33 AM
Shagwell's Avatar
Originally Posted by KITT1983
it has two cables either 2 round or 1 round and 1 square
Now that you've explained what you're talking about, maybe someone can help.
Old Jan 16, 2009 | 12:35 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It has 1 lock cable and 1 shifter cable. AFAIK there are no differences between years and models in either cable.
BRoss99
Aug 10, 2025 05:08 PM
9192camaro
16
Feb 3, 2019 12:21 AM
g.l.mos
Aug 22, 2015 12:02 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
