T5 vs T56 flywheel
Car: 88IROC, 91Z28 + parts cars
Engine: 355, 408
Axle/Gears: 3.42 LS1, 9" w/ 4.56 and spool
T5 vs T56 flywheel
I have a T5 behing my 350 right now and i want to do a cam swap. If I do that I know the T5 won't hold up very long. I have a T56 from a 97Z28 in the garage. I was wondering if I can use the flywheel I have now and just switch to an LT1 starter or if I need to get a new flywheel too.
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
Re: T5 vs T56 flywheel
you should use the lt1 flywheel it has more area for clutch engagement,larger clutch 11" instead of 10.4
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
You must use the LT1 flywheel with the LT1 clutch and transmission setup.
Be aware of the differences in flywheels between 1-piece rear main seals and 2-piece rear main seals. All LT1's have 1-piece flywheels. If your engine is a 2-piece you will need a special aftermarket flywheel.
Engine: 355, 408
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
the flywheel from the tpi cars wont work with the t56 totally 2 different setups u need ALL the stuff from the t56 to swap them over cause the clutch setup is totally different
I used a special 10.9" clutch from McLeod when I had a T5, so I'm guessing the T5 flywheel is 11" across also.
Car: Camaro coupe
My question is along the same lines but the other way around. LT1 motor and flywheel with a T5 trans. can you do that, since you just said the T56 flywheel has more surface area, or would you need a T5 flywheel....
Car: `86 SS / `87 SS
T5 / 305 starter will work with the T56. http://monte-list.com/html/images/ma...s/P1010066.JPG Or the LT1 starter (there are two; check price and core charge before you choose) or the C4 Vette starter without a support on the end of the pinion gear works.
The 4th gen F LT1 clutch disc hub does not fit in the T5 flywheel against the flywheel to crank bolts. If the C4 Vette pressure plate bolted to a T5 flywheel, you could use that clutch assy. since the hub is not sprung like the 4th Gen F disc hub, but a solid disc hub clutch is going to be a rougher drive.
Qualifier: I have an LT1 T56 (1995) and am using third gen T5 flywheel and clutch. But, I am running mechanical linkage AND it required sleeving the o.d. of the bearing retainer on the trans. to a larger o.d. and other little custom bits. Trust me, just buy the right flywheel.
Car: Camaro coupe
and the LT1 is a 2 piece seal correct. so i'd need say a late 80's early 90's t5 flywheel. or would one work off of a 4th gen T5. I dont know what years the T5 came in.
It's not worth it to try and use an LT1 flywheel with a T5; just get the T5 flywheel.
monte87cortez
Sep 26, 2015 08:10 PM
