Can the B&M shifter be installed in my car?
Old Apr 23, 2001 | 06:56 PM
Joseph Andres's Avatar
Car: 1991 GTA Convertible
Can the B&M Automatic shifter be installed in a 88 Trans Am without hacking up the interior console. Is it a complete bolt on and pretty straight forward install?
http://store.summitracing.com/partdetail.asp?part=10280
1988 GTA 5.7L TPI Auto
355 ci. block,TPIS ZZ-9 Camshaft, SLP Headers, Borla Cat Back, B&M Holeshot 2400 Stall Converter, 3.73 Richmond Gears
"Why ride a stang when birds can fly?"
http://www.geocities.com/thegta
Old Apr 23, 2001 | 07:15 PM
hookin88formula's Avatar
yes it will bolt right up in your car unlike mine. my car is a formula and the center console is different the install is pretty easy except for the relay u have to hookup that doesnt come with the shifter. so read the directions before u start the install and go to radio shack or a hardware store and pick on up.. other then drilling a few holes it bolts right up. hope this helps
1988 firebird ws6 formula350tpi ascd ram air hood GT AUTO 4th gen spoiler black paint with blue pearl centerline champ 500 16x8 all around potenza 245 50 16 on front and 27x11.5 16 mickey thompson sportsman pros on the rear(real sticky!!) msd 6al box blaster 3 coil accel 8.8 race wires hooker shorty headers hooker cat back system pro shift light A pillar gauge pod and water temp and air/fuel ratio gauges autometer oil pressure gauge b&m mega console shifter vette servo custom ram air system with a 9" K&N cone filter tb coolant bypass slp runners polished plenum and runners 170* thermostat smog pump and a/c delete plus cat delete march underdrive pullies, tpis airfoil cvr high torque starter (love it) aluminum drive shaft
best 1/4 mile run of 14.44@ 96.53
this run is before the new exhaust system new sticky tires coolant by pass smog removal new runners new thermostat and new three core radiator since i would get to the line and be well over 220* aluminum drive shaft and vette servo
NBrehm
Aug 25, 2015 11:49 PM
86IROC112
Aug 17, 2015 02:00 PM
mustangman65_79
Aug 13, 2015 07:36 AM
bryan623
Aug 10, 2015 11:33 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
