Will swap from 2.73 to 3.73 gears help acceleration?
Old Apr 23, 2001 | 02:12 PM
87FormulaGuy's Avatar
Hi everyone,
I currently have an 87 Formula with the LG4/5spd combo, and an open diff 2.73 out back. I've been offered a free 3.73 open diff. rear end out of an 84 or 86 camaro v-6, or so he said. Will this bolt up to my car, and what kind of a difference would I see in acceleration (0-60 or quarter mile?) The car is near stock except for an open element, catback and high flow cat. Also would my rpm's be unreasonable on the highway? Thanks alot,
Steve
Old Apr 23, 2001 | 02:43 PM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
It should bolt right up. You wil DEFINATELY notice a difference, probably a substanstial difference.
My 1986 Z28
GM350, T-5, 3.23's, lots of go fast goodies, 4th gen Firebird interior etc...
85 IROC w/ 1364 miles!
You'll always find what you've lost in the last place you look
R.I.P Dale Earnhardt
Old Apr 23, 2001 | 03:03 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
That 3.73/open/drum axle probably came out of the rare '84 Camaro H.O. car... no V6 came with 3.73's. The lowest gear the V6's got was 3.42's. I think the manual transmission'd 2.5l 4cyl f-bodies recieved 3.73 axles, though. All of GM's rear f-body axles were built to the same strength, no matter what engine went into the car.
[edit] Oh the only thing you should replace is the body-to-axle brake hose, for safety's sake. I went from a 3.42/open/drum axle to an '84 3.73/posi/disc, and the gears made my car feel much stronger- you should feel one helluva improvement from 2.73 to 3.73!
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
[This message has been edited by TomP (edited April 23, 2001).]
Old Apr 25, 2001 | 10:06 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
You will definetly feel a huge improvement in acceleration. The hardest part with the swap will be the speedo gear replacement. Its just a pain to get the driven gear off the output shaft on the trans. Remember to replace the flexible hose from the body to the axle.
I did this same swap in my 89 305 TPI. Say good bye to fuel economy and hello to fun though!
I found that i get bad vibration above 80 MPH. Let me know if you have the same problem.
  • 89 Formula 305 WS6
    SFC's
    LCA's
    Spohn Panhard Bar
    Air Foil
    Flowmaster Cat Back
    Tranny Cooler
    A/F Ratio Meter (not a mod but it sure spurs interest)
    Trans Temp Gauge
    Most "Free" Mods
    3:73, Zexel Torsion Posi
  • 90 Eagle Talon 2.0
    (Winter Beater)
    Mods? Um, no
hectre13
Dec 11, 2023 08:14 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
Dialed_In
Aug 20, 2015 01:45 PM
mizz0313
Aug 12, 2015 06:45 AM
