700r4 shifting too early
i have a v6 engine..84 with a 70r4 tranny on it....just replaced the throttle valve (over drive) cable...and the overdrive is working great...but for some reason the transmission is now shift way to early..hitting 3rd at low RPM..and bogging to engine down nearly to a stall before coming back up....any idea of what could be causing this?
1984 Fire Engine Red Pontiac Firebird...2.8L V6..173CI...2BBL Carb..15 inch wheels..o.o
The TV cable is out of adjustment. You'll need to adjust the TV cable, since you said you have replaced it the settings have changed. Follow the manual on this if you have one.
Hope This Helps!!!
Hope This Helps!!!
Car: 99 Formula
Axle/Gears: 342
So the TV cable also controls OD, my OD has never worked since I got the car, and right now for some reason I can't seem to get it adjusted right, I have recently lost 2nd gear, it shifts late from first then into 2nd for maybe a second and then into 3rd.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER
EDELBROCK 600CFM CARB.
KN AIRFILTER
UNDERDRIVE PULLEY
ACCEL HEI DISTRIBUTOR
2:73 GEARS
'86 IROC
GM GOODWRENCH 350
FLOWMASTER
KN AIRFILTER
UNDERDRIVE PULLEY
2:73 GEARS
Do this: A)Loosen the cable. B) Make sure the throttle blade goes full, bend brackets, whatever till it does. C) With throttle still full, press the D button and pull the cable back all of the way, as far back as you can and release the D button. D) Mark the cable for future reference.
You now have the cable and throttle set for true WOT AT WOT.
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
TX-SleeperC5
Sep 24, 2015 03:13 PM
