Update on two old posts & a plug (non-thirdgen)
Old Apr 26, 2001 | 04:00 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I got the Shoebox back on the road yesterday, results of a couple of questions finally in. I haven't had it to the track yet, but did do a couple of "on-ramp test runs", as well as cruise and stop-and-go.
First, the orginal at https://www.thirdgen.org/messgboard/...ML/001528.html about the burnt TH400 clutches and band. I put the check ***** back where TCI said to put them. It shifts great, either auto or manual shifting, doesn't slip in 3rd. It's never felt better.
Second, orginal post at https://www.thirdgen.org/messgboard/...ML/001993.html about what shifter to use. I went with the Light Truck MegaShifter. I have it almost all the way up, so "normal" shifters would have had me bent over - glad I made that choice. It is normal-gate from park to drive, easy to use on the street; ratchet from drive to first both ways. I need more practice with the ratchet, but it seems pretty natural already (find myself thinking that's the way the Camaro shifts, too).
Finally, the plug: I filled the tranny with AMSOIL's new "Super Shift" fluid. It is full synthetic without the friction modifiers. They don't recommend it for the street because of harsh shifting. However, since it only took seven quarts to fill after the rebuild, I still have some "normal" fluid in it (AMSOIL synthetic ATF, of course) that was left in the converter, which is higher-than-stock stall. The shifts are very firm and precise, but not harse, either around town or WOT. If you want a fluid that gives you firm shifts and the protection of a synthetic base, I'd highly recommend this product - especially for racing.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" Hedders, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere w/open diff & slipping tranny. Daily driver while Camaro was being put together.
Old Apr 26, 2001 | 05:48 PM
ede's Avatar
ede
send me a case or two of amsoil so i can plug it too. i can't believe the amount of times i do recommend a product on here by name. i'm not sure if anyone listens or not but i'd guess from a few of the e mails i get someone does.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Apr 26, 2001 | 06:11 PM
five7kid's Avatar
Hey, like I've said before: Name, delivery address, what you'd like to try, name of first-born male...
Old Apr 27, 2001 | 04:56 PM
ede's Avatar
ede
po box 355
jackson, ohio
45640
Christopher Lee
send me anything and i'll be happy. motor oil is the most likely to get used the quickest, not real crazey on 0-30 oils.
ICON Motorsports
1st & 3rd
[This message has been edited by ede (edited April 28, 2001).]
eightsixseven
Dec 16, 2024 01:50 PM
specialized
Jun 18, 2022 09:26 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
BurlyChev
Aug 22, 2015 01:52 PM
