what rear end? need help
Car: 1982 Chevrolet Camaro Z28
Engine: LG4
Transmission: TH350
does anyone know what kind of diff an 82 z28 came with does it have posi-trac just curiouse if no posi trac from stock anyone know good deals on posi-track diffs that'll fit in a 82 z28
Re: what rear end? need help
The '82 has the 7.5 10 bolt with 26 spline axles. It comes stock with a standard differential, but could be ordered with a limited slip differential (posi). The RPO decal will tell you if your car came with the posi or not, but if the rear end has been changed then you won't know what is in it. Many of these cars came with the Governor Lock differential, which isn't the best for high performance use. They have a lot of small parts that can break easily. The Auburn was also used in some of them. The best in my opinion is the Eaton posi. They were not offered in the '82 and later Camaro, but were used in the '60s and '70s Chevy muscle cars. You can get a new 26 spline Eaton posi for $427 that will fit your car. Another $30 will get you the bearings and shims for it. You must know what gears are in your rear end before changing anything in it.
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
my '82z (LG4/4spd super t-10 came with 3.23 open rear,
all the crossfire cars i have checked have had posi rears.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
