T5 to Gen III or IV motor?
Old Jan 23, 2009 | 01:02 PM
whitess's Avatar
Car: 85 SS
Engine: 305 L69
Transmission: 2004R
Axle/Gears: 7.625, 3.73
Will the stock bellhousing bolt up to these motors? If so what flywheel setup would you use?
Thanks,
Larry.
Old Jan 24, 2009 | 09:31 PM
ls six's Avatar
Re: T5 to Gen III or IV motor?
Thanks,
Larry.
Sorry but they wont. The Gen III and later sbc's moved the bellhousing mounting surface .500" forward while the crank flange remained in the same position. This means that the trans for these motors needed a .500" deeper bellhousing to provide converter clearance and earlier transmissions will either not fit or cause the converter tp bind destroying the pump instantly.
Anso since there was no room for the top passengerside bold because of the rear most cylinder they deleated that hole in the block ( the trans still has that hole ) and added a new hole at the 12:00 position of the block and trans.
Old Jan 25, 2009 | 12:59 PM
whitess's Avatar
Car: 85 SS
Engine: 305 L69
Transmission: 2004R
Thanks.
Old Jan 25, 2009 | 08:42 PM
ls six's Avatar
I forgot you were talking about a manual somewhere during my response lol but most of that still applies. Instead of converter clearance the input shaft will hit the crank before the bellhousing touches.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
ezobens
Aug 19, 2015 10:29 PM
Elliswon
Aug 10, 2015 12:33 PM
