need help picking new studs for new axles
Old Jan 25, 2009 | 09:09 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
I need to pick out new wheel studs for my axles but I cant figure out which knurl to get. I got superior axles with the 7/16 press in or 1/2 screw in stud holes. I think all I need is the 7/16 for the street. Knurl sizes come any thing from .468-.580. Since nothing has ever been pressed in these axles I would believe I would need the smallest dia. ? Here is a list of studs im picking from. Your help is apperciated.
http://store.summitracing.com/egnsea...115+4294902769
Old Jan 25, 2009 | 09:12 AM
big gear head's Avatar
Re: need help picking new studs for new axels
You need to measure the hole size and then go to the auto parts store and see what knurl size fits that hole. They will have a book that will tell you which one fits the hole. The knurl will be larger than the hole.
Why didn't you go back with the metric studs?
Old Jan 25, 2009 | 10:14 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Why didn't you go back with the metric studs?[/quote]
Because they didnt offer the axles in metric that are hevy duty. The better axles are what I ordered.
Old Jan 25, 2009 | 10:21 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The metric size is 12mm. That's almost the same as 7/16. There should be a knurled end that will fit the hole for both sizes. As mentioned above, the size of the knurl you need depends on the hole size.
Go with the 1/2" screw in studs. They're easier to install.
Old Jan 25, 2009 | 12:46 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
I was thinking about them but im trying to figure out if they would work with the rims I have. Cause I need new lug nuts and the 1/2 size is bigger I thought that they might not work with my rims.
Old Jan 25, 2009 | 01:54 PM
I haven't seen a wheel that wouldn't work with both 7/16 and 1/2 inch studs.
6speedIROC
16
Mar 15, 2023 08:33 PM
dbrochard
Oct 3, 2015 12:43 PM
New2Chevy
Sep 28, 2015 12:35 AM
355tpipickup
Sep 13, 2015 11:35 PM
89-91fun
South West Region
Sep 12, 2015 03:06 PM
