best place to find 3.73 posi rearend
Car: 2000 TRANS AM
Engine: H,C,I LS1
Axle/Gears: 3.42 posi
would like to find a 373 posi rearend
should i junkyard one from another f-body
how much to buy new ring&pinion plus posi unit? labor cost at shop?
thanks
thanks
Car: 1991 Z28 convertible
Transmission: TH-700R4
Axle/Gears: 3.73 posi 4th gen 10-bolt
Re: best place to find 3.73 posi rearend
Some of the 4th gens had it with disc brakes. I have a 91 z28 vert that the previous owner put one in. It's pretty much a direct bolt in, the parking brake cables are different though between a 3rd and 4th gen. The only thing that will happen if you get one is the rear end on a 4th gen is about 2 inches wider, so each tire will stick about bout an inch or so more than a stock 3rd gen rear. On my car, it puts the outer edge of the tire pretty much right in line with the outer edge of the quarter panel. I like it, it isn't bad.
Car: 1984 TA 15th Anniv. Addition
Engine: 355 SBC
Transmission: TH350
Axle/Gears: 4.56
I have my used set of richmond gears for the 10 bolt. they are 3.73. I will sell to you. Let me know if your interested.
hectre13
Dec 11, 2023 08:14 AM
ambainb
Apr 25, 2016 09:21 PM
hectre13
Aug 26, 2015 08:17 AM
Dialed_In
Aug 20, 2015 01:45 PM
