T-5 Speedo Gear Colors...
Need some quick help from someone on the color of the driven speedo gears in a Borg Warner T-5. I put one in last night and the old one had a dark blue gear and the new one has a light purple gear. Both input speedo gears are red and have the same teeth...so those are fine. I just want to know how much (if any) will the other gear throw off my speedo. The dark blue one has 6 teeth, and the light purple one has 8...so my speedo will be reading faster with the light purple one...correct? If so then how much?
Thanks in advance!
Formerly known as 1984L69Z28
1984 Z28 - L69 optioned, 350HO w/ Trick Flow Heads, Drop Forged Lunati Crank, Crane Cam and 1.5 Roller Rockers, Stock Z28 Intake Manifold, Highly Tweaked Rochester Carb(700cfm), K&N Filter, ThermoMaster Chip w/ 160 Stat, Comp Headers, 3" Stainless Dual Exhaust w/ no Cat & Dynoflow Muffler, 4 wheel disc brakes, etc....
God bless us father, son, and holy ghost....whoever goes the fastest wins the most!!
[This message has been edited by 350HOZ28 (edited May 01, 2001).]
Thanks in advance!
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
You have a 9 tooth red drive gear inside the trans now? For a 3.73 rear end? Wow... I thought the combo was 7 tooth and 21 tooth for 3.73 rear end.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.23 @ 107.62 MPH
Southern California
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Thanks!
