which speedo gear
Old Jan 29, 2009 | 02:51 PM
da_jester's Avatar
Car: 1992 camaro rs
which speedo gear
ok guys ive searched and i cant find this out i have a 92 rs camaro with a 305 tbi and 700r4 im swapping out my gears over winter for a posi unit and 3.73 gears which speedo gear do i need?
Old Jan 29, 2009 | 05:03 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Re: which speedo gear
http://www.transmissioncenter.net/sp...n_______va.htm
How you didn't find the info is beyond me, this has been covered a million times
With 15 Tooth Drive Gear
Axle Ratio - Tire Height - Driven Gear Teeth
3.73 - 26 - 43
3.73 - 27 - 42
3.73 - 27 1/2 - 41
3.73 - 28 - 40
3.73 - 29 - 39
3.73 - 30 - 38
3.73 - 31 - 36
With 17 Tooth Drive Gear (your car should have this gear already in it)
3.73 - 28 - 45
3.73 - 29 - 44
EDIT: You may not like 3.73s, I put 3.42s in my TBI/auto car, went to 3.23s, much better. But I do drive on the highway daily.
Old Jan 29, 2009 | 09:14 PM
da_jester's Avatar
Car: 1992 camaro rs
yeah i dont do much high way driving but if 3.73s are to high sprung i will drop down already thought about it just i got posi unit gear ring and pinion from a friend for dirt cheap. and my tires are 26.18 inches so 26 so i would get 43?
Old Jan 29, 2009 | 09:23 PM
krisb410's Avatar
As long as you also get the 15 tooth drive gear to go along with the 43 tooth driven gear. Make sure you buy the gear for the VSS, and not for the mechanical setup.
BTW: Your posts are hard to read, use proper punctuation to make it easier for the reader.
Old Jan 30, 2009 | 09:17 AM
da_jester's Avatar
Car: 1992 camaro rs
ok im sorry for the punctuation.ok so i should have the 17 tooth gear in my car but i didnt see the rite set up cause i dont have 28 inch tires.
Old Jan 30, 2009 | 09:22 AM
da_jester's Avatar
Car: 1992 camaro rs
when i figureds mine out i got 49.09 for the driven teeth
Old Jan 30, 2009 | 09:54 AM
krisb410's Avatar
You will need to buy the 15 tooth gear, and the 43 tooth gear
They don't make a 49 tooth gear, that's why you need to change both gears. They only go up to a 45 tooth gear
Old Jan 30, 2009 | 04:41 PM
da_jester's Avatar
Car: 1992 camaro rs
ok thank you
Old Jun 17, 2013 | 03:12 PM
RRUHL's Avatar
Car: 92 RS
Engine: 350 5.7 TPI from 91z28
Transmission: 700R4 transgo shift kit
Axle/Gears: 84z28 Disk brake with 3.23s
Not to bring up a dead post but similar issue 92 rs 91 350 tpi swapped in already did buffer bypass and all those issues....ok now for problem and setup...... 323 disk rear from 84 maro does any one know what tooth count I would need? 215 65 r15s 92 700r4 thank you any info greatly appreciated....can't get the car over 80 speedo pins and spark over advances thank you
Old Jun 17, 2013 | 07:45 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Ready the speedo gear stickies at top of this page
https://www.thirdgen.org/forums/tran...eedometer.html
GTAman
Jul 3, 2024 07:29 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
88rscamar0
Sep 23, 2015 09:08 PM
andy74
Sep 3, 2015 08:41 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
