Why doesn't the VSS out of 700R4 work in T-56??
Old May 2, 2001 | 12:05 AM
Greg's Avatar
Car: 89 Formula T-Top
Engine: 388 MiniramII
What is the big deal here? Is the diameter different for the 700R4 VSS than the T-56 VSS? It seems like it would be easier to make an adapter than to wire up a box that adjusts the pulses. Or is there something else going on here?
'89 Formula 383 TPI
Old May 2, 2001 | 01:50 PM
FormulaJoe's Avatar
Thats a good question. I wanna know too, lets take it to the top.
L98, 3.27 9-bolt, Hooker shorty headers, custom 2.5inch Y-pipe, no cat, 3inch 2chamber flowmaster, JET AFPR, Ported MAF, Best ET: 13.86 @100mph. 1.99 60'
17 inch ROH "ZS" wheels. 17x8.5(front) and 17x9.5 (rear). Firestone Firehawk SZ50s. 245/45/zr17s and 275/40/zr17s. T56
On the way... Radar Blue 89 Formula, T56, Ram Jet 430, Ram Air, 17inch ROHs.
Old May 2, 2001 | 07:07 PM
Greg's Avatar
If nobody knows the answer here than this is a problem. I'm not going to mess with a $90 box thingy with lots of wires if all I have to do to my stock VSS is get it mounted in the T-56 somehow.
'89 Formula 383 TPI
Old May 2, 2001 | 09:09 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
Since it appears that your car has the VSS mounted in the transmission, as compared to having a cable, and the VSS being on the back of the speedo head, I think you should be able to use the T56 VSS. I'm not sure about the plug on it, so you may need to change it.
I could be wrong, so you may want to wait for someone else to verify it.
Working on:
'84 Z28 LG4 305 with 200,000 original miles!
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350 (ZZ430)
using primarily GMPP parts.
Short block sitting on a stand. (Man, those Fast-Burn heads sitting on it look good!)
Starting to look like the Kicker poster child!
ASE Certified Master Tech
[This message has been edited by JP84Z430HP (edited May 02, 2001).]
Old May 3, 2001 | 08:31 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Yah, the two VSS's are different sizes, plus they put out different signals, so they're not compatible with each other.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old May 3, 2001 | 09:58 PM
JP84Z430HP's Avatar
Car: 84 Z28
Sorry, I was under the impression that they put out the same signal! Maybe I should look at the manual BEFORE answering questions.
Later
Old May 4, 2001 | 02:13 PM
Greg's Avatar
Kevin
so if my stock VSS was the correct diamter as the T-56 VSS than I would be able to mount it into the transmission?
'89 Formula 383 TPI
BlueIroc-Z
Jun 9, 2019 03:22 AM
Reddeath210
Oct 6, 2015 08:20 AM
fonzie85
Aug 13, 2015 11:50 AM
mizz0313
Aug 12, 2015 06:45 AM
cRoe4
Aug 7, 2015 08:46 PM
