really dumb question, how many gears do i have
Car: 1989 Iroc Z L98
i just bought this car from a lot a few months ago, and i am still trying to decifer this transmission. the shifter plate on it says:
1 2 D OD N R P
is this considered a 4 speed or 3 speed. also, what transmission is it? it is an 82 berlinetta, but i dont think it is a 200c because it has overdrive
thanks
1 2 D OD N R P
thanks
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Sounds like someone installed a 700R4 into your car and also put in the proper shifter and shift indicator.
Car: 88 Firebird WS6
Assuming it isn't the stock tranny, it may be a 2004R which would be an easier swap.... But most likely a 700R4.
The 700R4's oil pan is pretty much rectangular while the 2004R's is very odd shaped and looks kinda like it has two seperate pans.
Either way... Yes a 4 speed
Car: 82 camaro SC
Maybe the shifter broke and they installed a later model shifter(it still would have the th200c). Shift it through every gear one by one to check. Just another possibility, people do dumb stuff everyday.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
[This message has been edited by 82camaro (edited May 02, 2001).]
82camaro
my shifter is really soft shifting through the gears, so icant tell. i thought of that possibility when i was putting up the post, i will get underneath and check lol.
Technically, The 700 Is a 3 spd W/ Overdrive.
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Reader's ride -> My Ride
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Isn't the OD, or 4th gear, a gear in itself with a .70 ratio? If so, that would make 4 gears.
1989 IROC-Z 5.7L
NOS 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
1989 IROC-Z 5.7L
NOS 150HP kit
The difference between a 3 speed and a four speed is that both planetarys are not joined on the same shaft like the 3 speed, so therefore it is a whole different gearing so I guess it's a 4 speed.
Car: 82 camaro SC
'overdriven or not' it has 4 different gear ratios's from input shaft to output shaft, so it's a 4 speed.
82camaro
82camaro
junkcltr
Aug 2, 2019 11:12 PM
NinjaNife
Aug 23, 2015 11:49 AM
