V6/V8 trans interchangability?
Old May 4, 2001 | 06:12 PM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
The question is can it happen. I never looked under a V6 thirdgen, but I've heard conflicting stories about if the trans under them fit V8 engines. I have a friend who want's my 700-R4, which is 27 spline, but built. He has a V6 with an almost-dead tranny. Will it work? Too dark outside to go out and look. Just want to double-check. Also, the car's and '89...what worries should I have regarding TCC lockup(connector)? Thanks
Old May 4, 2001 | 06:26 PM
clemsparks's Avatar
Car: 1983 Z28
Transmission: WCT5
Correct me if I'm wrong someone, but isn't the bellhousing bolt pattern totally different since the V8 is a 90 degree engine and the V6 is a 60 degree engine?
HTH
Clem
Clem
SCCA TransAm Series Race Mechanic/CrewChief
1983 Z28 with LG4, 5 speed, and (unfortunately) T-tops
1983 Z28, NO T-tops, (unfortunately) Auto Transmission---FOR SALE---
Looking for a V8, preferably 4 or 5 speed Camaro with NO T-tops (wanna trade?)
Old May 7, 2001 | 12:48 PM
82camaro's Avatar
Car: 82 camaro SC
If it's a 4.3L v6, it will work. Otherwise the bolt pattern is different.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old May 7, 2001 | 01:57 PM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
If the v6 in question is anything but a 4.3L, the answer is:
If it's an auto, no, it will not work. Period.
If it's a stick, you can build a bastardized hybrid with a v8 bellhousing and a v6 tranny, but I don't see why you'd want to, because the spline count on the input shaft is different necessitating a custom clutch disc, or using the puny v6 disc.
4.3L V6 shares the same bellhousing pattern with the SBC and will work fine.
Old May 7, 2001 | 05:58 PM
dhirocz's Avatar
Yep. Found out Saturday. Tranny looks the same except for the bellhousing. Thought they were all the same...damn! Oh well, maybe he'd like a motor, too . Thanks, guys.
Old May 8, 2001 | 06:48 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Actually the 4.3 is internally weaker, so if you plan on beating it.....
It's like a case of a v6 5 speed bolting to a v8 with the v8 bellhousing.... Who would do this just to end up doing it over.
1992 Trans Am
May 10, 2023 07:19 PM
Hawk312
Aug 22, 2017 08:55 PM
Hello, Michael
Aug 20, 2015 03:19 PM
mizz0313
Aug 12, 2015 06:45 AM
Leggman1
Aug 6, 2015 04:15 AM
