Is the axle code always on the tube???
Old May 7, 2001 | 03:39 PM
Mike-88CamaroTBI's Avatar
A friend and I both stared at the rear axle housing on my 88Camaro SC for about 30 minutes.
The only markings we could find were csat on the hogs head.
We looked at the front and rear of the axle tubes on both the driver and passenger side.
I am trying to determine if my late 1988 model run SC has a 28 spline axle.
Here is what I found on the hogs head.
Does this mean anything
22522676
K16 GMN E
16 8 28
1988 Camaro Sport Coupe305TBI-4spdAOD-2.73open in "bought stock" condition. That'll change if it stays around here much longer mike.davis@firstunion.com
Old May 7, 2001 | 03:59 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Those suckers are hidden! All the rust & grime makes them hard to see.. they're stamped in, and not cast in. To find mine, I wire brushed the heck out of the front of the passenger side tube. Then, I wet my finger, and ran it across the area... the numbers showed up.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old May 7, 2001 | 06:56 PM
coach's Avatar
You're not alone guys! I was working under the car a while back, and I decided to look for the code. I wire brushed and nothing. I didn't wet the area though. That'll probably do the trick.
I've got a 92RS,305tbi,auto. What I've read say's that my car is equipped with the 2.73 POSI. Should I trust the info or check to see if it's got the 3.23std?
Old May 7, 2001 | 06:58 PM
coach's Avatar
One more question. Could the code rust to the point where it would disappear if wire brushed?
Old May 8, 2001 | 11:19 PM
jaretz28's Avatar
On your year car I doubt the rust could already make it disappear. I have an '83 Z28 and even mine is still there. Just look a tiny bit harder.
Old Jan 8, 2002 | 12:09 AM
slen2's Avatar
mike-88camaro
I am looking for the same thing as you and I have the exact same stock setup as you. Where should i look for the numbers and what determines if it is a 28 spline axle because i was told it would be a 26 spline.
z 28 jari
Sep 14, 2021 10:03 PM
BumpaD82
Feb 26, 2016 02:57 PM
3rdgenkindagal
Sep 13, 2015 02:02 PM
dbrochard
Sep 7, 2015 09:41 AM
rudolphschenker
Sep 4, 2015 02:41 AM
