Vibration
Old May 4, 2001 | 12:31 PM
MINN IROC-Z's Avatar
Car: 1988 IROC Z
Vibration
Hi guys
I just got my camaro together and put the engine back in. I never took out the transmission just motor and driveshaft. I updated the motor with ported heads and cam change and while I was at ported the intake. I removed my drivshaft to change u-joints because I had a slight vibration last fall. After my recent changes this spring it seems to be worse. My driveshaft is steel and the vibration is the worst between 70 and 100 mile per hour. I am just unsure of what to try next and could it be an out of balance driveshaft? Should I go to aluminum? Thanks for your input. Dennis
Old May 4, 2001 | 04:36 PM
BlackZee's Avatar
Go with an aluminum driveshaft, they are specifically made for high performance and are held to tighter tolerances during the manufacturing process. I purchased mine from James C. in Kansas, he is a class act! Watch the classifieds for one of his ads and email him with your request, if interested.
Good luck and enjoy!!
Old May 7, 2001 | 11:12 PM
SUPER-SPORT-CHEVY's Avatar
yep that 70-100 hits home. "same problem same speeds as you" Its the driveshaft! Get it highspeed ballanced and it will go away.
SSC
Old May 9, 2001 | 01:35 PM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
I had/have the same problem. Getting it balanced was $85 and a used Al one is $120-160.
The balance helped a little, but now that i have 3:73's It won't go away.. well it does around 110 mph and up. Mine is nasty around 80 mph.
  • 89 Formula 305 WS6
    SFC's, LCA's,
    Spohn Panhard Bar
    Air Foil
    Flowmaster Cat Back
    Tranny Cooler
    A/F Ratio Meter (not a mod but it sure spurs interest)
    Trans Temp Gauge
    Most "Free" Mods
    3:73, Zexel Torsion Posi
  • 90 Eagle Talon 2.0
    (Winter Beater)
    Mods? Um, no
Old May 9, 2001 | 02:22 PM
PonchoTA's Avatar
You might try, for a temp. fix, turning the d/s over 180*, from the differential side. The steel d/s has a balance weight attached to one side, and sometimes it is just enough to throw the balance out at higher speeds. I had a '78 T/A that I replaced the u-joints and then had a nasty vibration problem. A friend suggested this and it went away!
Hope this helps.
Old May 10, 2001 | 07:55 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Black Zee,
Many thanks for the plug. I do have an alum shaft from a 90 Camaro. Should anyone be interested, please see my ad in the classifieds.
JamesC
Old May 10, 2001 | 08:56 PM
need4speed's Avatar
Read this first.
http://www.drivetrain.com/driveline_angle_problem.html
Check your driveline angle, sometimes a collapsed trans mount will throw things off.
Then go pay $85.00 for the driveshaft to be high speed balanced. They are not balanced for high speed from the factory. The shaft is balanced so it doesn't vibrate at 65 mph.
69GTOby
Apr 18, 2016 02:34 PM
sac92transam
Oct 7, 2015 02:31 PM
roysatikas
Sep 22, 2015 08:15 PM
BWilcox
Sep 20, 2015 12:19 PM
InfinityShade
Sep 18, 2015 08:32 PM
