Manual Swap- Pedal Installation
Hi All.
Could someone who has done this, give me some tips on the installation of the pedal assembly and hydraulics. I am doing this on friday, and really need some help here cuz i have never done this
any other tips on the conversion would be greatly appreciated
thanks
COUGAR
thanks
COUGAR
Here's what I suggest. It worked great for me. Take out your old pedals. I'm assuming you have an automatic now. I got the bolts to start coming off by just using an open wrench. Then I took my 5/8 spark plug socket and even though it wasn't the same exact size it took the bolts off easily since they were loose. If you have the right size deep socket you'll be fine. It just has to be a deep socket. Disconnect the brake booster and pull the assembly out. You shouldn't have to drop the steering column. Everyone thinks you do and they will say it, but you don't have to. Put the new assembly in. Don't worry about drilling the hole for the hydraulics yet. Don't worry about a template. Just put the pedals in. Then just take a dril and use the bracket on the installed pedals as a template. The bracket will act as a guide for the drill. It will then be EXACTLY where you need it. Drill lots of little holes in the center for the master cylinder and pop out the center with a screw driver. You can then clean the edges up with a dremel or something. Bolt in the hydraulics and connect the rods and that's it. Have fun!
88 firebird formula
350 Vortec TBI
214int/224exh, .471int/.491exh
Edelbrock headers
T56 - SIX-speed
open 3.73's
2 1/4 stock catback
I love pissing those LS1's off
My Formula
All your base are belong to us.
88 firebird formula
350 Vortec TBI
Edelbrock headers
T56 - SIX-speed
open 3.73's
2 1/4 stock catback
My Formula
When i swapped i my t-5, i already had a whole for the clutch cylinder that was being used by some electrical connector, so i just moved the electrical connector. To get out the bolts I loostened the steering column bolts to get a little more room and then used a socket with a u joint and a bunch of extensions. Not an easy job but it can be dont. Theres a bolt all the way up in the "celing" of the area where the pedals are that is easy to overlook.
Good luck with the swap.
1992 Trans Am
May 10, 2023 07:19 PM
ambainb
Apr 25, 2016 09:21 PM
