How many miles has everyones 700r4 lasted without modification....I'm getting a new engine and need to know probably an average when my trans will go so I can be prepared.....
IROC-Z
G92, LB9 305 TPI, 3.23
IROC-Z
1989 Formula 350:
Trans lasted 80,250 miles.
At least 250 drag strip passes and many more public road passes.
Most seem to last 65K to 75K miles. I changed the fluid and filter in mine at 50K, most never change it all.
I know a guy that has 270k on his 700r4 and no problems even the engine is fairly good shape. as long as you take care of them they last a very long time.
Mine now has a little over 100K miles. I have only put about 10K on it myself, but i am a hard driver... Although i did install a tranny cooler.
- 89 Formula 305 WS6
SFC's, LCA's,
Spohn Panhard Bar
Air Foil
Flowmaster Cat Back
Tranny Cooler
A/F Ratio Meter (not a mod but it sure spurs interest)
Trans Temp Gauge
Most "Free" Mods
3:73, Zexel Torsion Posi - 90 Eagle Talon 2.0
(Winter Beater)
Mods? Um, no
My first one was beat to hell and back and lasted well over 135K! but the rebulid I got was shi*! That only lasted about 15K! Needless to say I'll never go to that shop again!
132.5k miles and still going strong. no mods to it yet.
Flowmaster 80 series muffler, K&N Open Element cleaner, Subframe Connectors + a lead pedal foot
. See my baby @
http://oursportscars.homestead.com/home.html
. See my baby @ http://oursportscars.homestead.com/home.html
Mine lasted for 103,000 miles.
EVILFACE
88 Camaro
Stock 305 TBI Auto,Flowmaster, Full 3" Exhaust, B&M Megashifter
Runs A Blistering 16.5 @ 81.5 mph
http://www.evilface.com/evilscamaro.htm
EVILFACE
88 Camaro
88 formula 350:
108,000
88 camaro 2.8
170,000 and still counting... although 2-3 seems a little softer (short slide) than it used to be but no one else notices.
Both abused severly, but maintained.
108,000
88 camaro 2.8
I have you all best!! If I get a cra with a 700R4 in it I can blow it up in no time flat. My car had a replacent already (193,000Km) and I got another one done at christmas. I got a 2000RPM stall and I got a shift kit and extra clutches put in 3rd and 4th cause the OD went. Last about 6 weeks and then the planetary blew up and spit shavings though everything and wrecked all the new stuff. I had another one out back that I had bought and turned out to be a dud too. I took the planetary out of that and with the 2 trannies I made another good one. Bought another new converter and I have driven this one about 10,000Km. Doesn't work as good as the old one though. My last car had a gm replacement and it started to go so i got it freshened up and it worked fine. I think these trannies SUCK! I would kill for a 4L80E or a T56. I don't even do burnouts!!! I don't know how all you guys get away with what u do to them!
Mine has a vette servo and nothing else. It has about 120,000 miles on it. I am not a very forgiving driver, and it still chirps on 1-2 shift and sometimes 2-3 shift.
Keep it maintained and they do last.
'88 RS (originally 2.8)
-350, .040 over, vette alum. L98s, stock tpi.
-305 injectors & chip
-TES headers & edelbrock cat back
-3.73 gears, 700r4.
Best with 2.8-17.4@77mph
Best with 305-15.0@93mph
Best with 356-13.7@101mph
on a 2.050 60 ft.
(Damn the 2.8!)
-3.73 gears, 700r4.
on a 2.050 60 ft.
(Damn the 2.8!)
mines got 158000 miles on it and still works great.
204,500 and still strong. I also, am not an easy driver, (can you say aggressive??? wore out a set of tires in about 20,000 miles that should have lasted 40,000, run it up to the redline in first and second, etc, etc....)
I got my car with about 165,000 on it, and the thing hasn't had an easy life since. I know for sure that it hasn't been apart (engine or trans) and it is still pretty strong.
The only problem I've had with the trans is the typical problem with shifting into third. It would only do it under heavy/full throttle. It has since started working the way it should eveytime now....Go figure!!!
Working on:
'84 Z28 LG4 305 with 200,000 original miles!
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350 (ZZ430)
using primarily GMPP parts.
Short block sitting on a stand. (Man, those Fast-Burn heads sitting on it look good!)
Starting to look like the Kicker poster child!
ASE Certified Master Tech
Working on:
145 MPH IROC Speedo
Quote:
<font face="Verdana, Arial" size="2">Originally posted by purpleworm:
Last about 6 weeks and then the planetary blew up and spit shavings though everything and wrecked all the new stuff!</font>
Sounds like your endplay wansn't set correctly. The factory uses a '68' selective washer for about .35" endplay...<font face="Verdana, Arial" size="2">Originally posted by purpleworm:
On a performace rebuild I usually use a '72' or better washer to bring endplay down to .05" to .00"
The weakest link in the 700's isn't the planetarys. It's not even in the top 4 weakest links so i would suspect something not set correctly.
I have 120,000 on mine and has a trans-go in it. It has never been repaired and no problems.
1987 Trans Am
5.0L TPI
Automatic, all pwr. op
Digital Dash
Flowmaster Muffler
gutted cat
removed MAF screens
TransGo Shift Kit
1987 Trans Am
5.0L TPI
Digital Dash
Flowmaster Muffler
gutted cat
removed MAF screens
TransGo Shift Kit
I have you all best!! If I get a cra with a 700R4 in it I can blow it up in no time flat. My car had a replacent already (193,000Km) and I got another one done at christmas. I got a 2000RPM stall and I got a shift kit and extra clutches put in 3rd and 4th cause the OD went. Last about 6 weeks and then the planetary blew up and spit shavings though everything and wrecked all the new stuff. I had another one out back that I had bought and turned out to be a dud too. I took the planetary out of that and with the 2 trannies I made another good one. Bought another new converter and I have driven this one about 10,000Km. Doesn't work as good as the old one though. My last car had a gm replacement and it started to go so i got it freshened up and it worked fine. I think these trannies SUCK! I would kill for a 4L80E or a T56. I don't even do burnouts!!! I don't know how all you guys get away with what u do to them!</font>
3 rebuilds and counting.....look for my post "quick question"
I would also kill for a T-56, but not for a 4L80E or any other automatic. I am sick and tired and also very frustrated with automatics.
Rick
'88 GTA 350 (very rusty)
Check out my car:
www.fortunecity.com/silverstone/brabham/42/
In my 82 Blazer it went out at 64,000 miles (GM repaired in under warranty). The next time was around 160,000 miles. The fellow that rebuilt it that time asked if I wanted all the heavy duty upgrades (pump, input shaft, bearings, torque converter, etc. that GM had since started using) and I said yes. Cost more for the rebuild but I haven't put enough more miles on it to say it will last longer (it's at 193,000 now). My son's 83Z has 170,000 plus on the odometer and he's put 30,000 of that on it with no breakdowns so far (it has always shifted funny though) and he runs the snot out of it. My 86 IROC has 124,000 on it but I haven't driven it enough to have any problems with it.
Z's r Best
Z's r Best
my original trans lasted 185,000 mi.
James
1985 Z-28 305 TPI 223,000+ mi., Original Eng.,T-Tops,Blue/Grey
STB,SFC,GW "wonderbar",145 Speedo
James
CamaroZ_85
close
- Join DateMay 2000
- LocationCentral NJ
- iTrader Positive Feedback0
- iTrader Feedback Score(0)
- Liked:63 Times in 48 Posts
I bought my car w/ 58k miles and it was on its second tranny already. 12k miles of my driving and it was time for another. put a used one in w/ a vette servo and it seems relatively tight for now...
85 Z28- 350, Comp 262, Edelbrock Performer intake, Edelbrock 600 cfm carb and Edelbrock cat back, Summit
headers and vette servo
-JVC, Eclipse, Pioneer, MTX, Phoenix Gold, Planet Audio
headers and vette servo-JVC, Eclipse, Pioneer, MTX, Phoenix Gold, Planet Audio
