Shift Improvment?
Old May 12, 2001 | 02:39 PM
MINN IROC-Z's Avatar
Car: 1988 IROC Z
Shift Improvment?
I just went through the motor and that works kick *** but I feel that the transmission needs a little help now. I stayed with the stock converter but what would you guys recommend for a shift kit? Who makes a fairly easy to install but a dependable kit? Is there any other things I can do to improve overall performance without putting to much money into it. Some of the shifts are a little sloppier than I would like. Any suggestions would be appreciated. Thanks Dennis
Old May 12, 2001 | 04:22 PM
Pro Built Automatics's Avatar
Use Trans-Go Performance Shift kit along with the Corvette servo, .471 or .500 main boost valve, .296 intermediate/reverse boost valve. This will give you the best results (performance & longevity).
Glad Too Help!!!
Old May 13, 2001 | 03:39 AM
transfixleo's Avatar
Ditto to what PRO said (plus dding a TruCool cooler). Let me just add that if you changed the induction on the engine then you will likely have to make changes to the TV linkage. You must have the proper geometry for the cable movement to get the desired signal to the tranny.
Old May 13, 2001 | 10:37 AM
Car: 1988 IROC Z
Thanks for the info guys but where do I go to get the Corvette servo and how hard is it to change because I'll do anything to a motor but auto transmissions make me a little nervous. Dennis
Old May 14, 2001 | 04:20 AM
Any Chevy dealer either will have it or can get it. You may find it in stock at a local tranny shop too. It isn't hard except for maybe having to pry the tranny over a bit for clearance.
F-body-fan
Jan 12, 2023 01:49 PM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
wanext
Oct 6, 2015 12:18 AM
racereese
Oct 3, 2015 03:46 PM
