T Lock
Old May 12, 2001 | 11:49 PM
Bort62's Avatar
T Lock
The Tlock Solenoid on the 700 Has what appears to be 4 Wires going Into It. Does anyone have a diagram or something detailing Wich of these does what ? With the intent of Fabbing a manual switch in Mind.
Thanks..
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Reader's ride -> My Ride
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Old May 13, 2001 | 03:36 AM
transfixleo's Avatar
The A wire is the 12 volt feed and the D wire goes back to the computer to complte the ground when L/U is controlled on. Depending on how the switches are inside the trans you can manipulate the ground on the tranny to enable L/U.
Old May 13, 2001 | 03:20 PM
Bort62's Avatar
So, theoretically, I could power the 12v A wire, and switch the D wire to ground, and In that manner control Lockup ?
Thanks.
Old May 13, 2001 | 04:47 PM
Yes, but you should already have the 12 volt signal so you would just have to take over the ground control. Bear in mind though that there is likely going to be a switch inside the trans that is inline with the circuit tht could have an effect on it too.
Old May 13, 2001 | 09:55 PM
Bort62's Avatar
Well the trans is going into a 78 vette, So there is no existing Source
When you say a switch inside the trans, You mean like a line pressure controlled lockup ? There shouldnt Be one, as the lockup is controlled by the computer...
Old May 14, 2001 | 04:14 AM
There are varying switch arrangements inside of these units (@20 different combo's). They are used to both send info back to the computer (the other wires) or are in series with the A and D wires to complete a circuit when a given gear is reached or to signal an interupt during a gear change. Some do have a direct in and out though. I can get the number for you if you want it.
Old May 14, 2001 | 02:09 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
From what I remember, there is a switch inside the trans that checks fluid pressure. Here's a link that has a wiring diagram for a 700r4 going into a non-computer-controlled car (it's at the bottom): http://www.thegrid.net/thedrivetrainpage/700inst.htm
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old May 14, 2001 | 04:32 PM
Here is the GM number for the straight in and out solenoid:#8654129.
jrdturbo
Mar 31, 2016 02:58 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
kkirch15
Sep 30, 2015 04:44 PM
Damon
Sep 26, 2015 04:29 PM
Dragonsys
Sep 25, 2015 03:51 PM
