shift kit
Old May 13, 2001 | 06:25 PM
robertlew's Avatar
shift kit
I have a shift kit in a 1988 GTA. It use to bark the tires on hard acceleration from first to second gear. Now it want bark the tires and it does not shift as hard. Has anyone had this problem.
Old May 14, 2001 | 04:05 AM
raven350's Avatar
Car: '89 Pontiac Firebird
Engine: 5.7L
Axle/Gears: 10-bolt w/ 4.10 and Eaton Posi
Which shift kit do you have???
How long has it been in the transmission???
How long since your last rebuild???
What kind of transimission do you have???
Sportsman II 72 CC heads, Pete Jackson gear drive, Performance Resources chip, Edelbrock 1 5/8" headers and Edelbrock cat back exhaust, hi-flow cats, Trans-go stage 3 shift kit, Vigilante 9.5" 2800 stall convertor, SLP cold air induction, SLP roller camshaft, 24lb ADS injectors, AFPR, 3.45 rear end gears, and other goodies...
raven
Old May 15, 2001 | 10:10 AM
robertlew's Avatar
I'm not sure what shift kit it has. It's an automatic in a 1988 Trans Am. I've had the car for about 8 months. It use to shift hard but now it doesn't.
[This message has been edited by robertlew (edited May 15, 2001).]
Old May 16, 2001 | 03:22 AM
transfixleo's Avatar
You may not have a 'shift kit' at all. These cars tend to act as you describe from the factory. A true Shift Kit (TransGo) isn't about how hard it shifts, but instead is about fixing the causes of complaints and failures in a particular transmission.
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
