Callin all T-56 swappers
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
I'm just curious..how hard is the swap from a 700r4 to a T-56? also would it bolt up to a GN/TTA turbo 3.8? i'm doing the swap either late this summer or this winter...i'm toying with the idea of a T-56 instead of the 200r4..any info would be great guys!
Originating member of the SJNEP Crew
Member of the Jersey Fbody Crew(JFA)
Check out MyGTA Nicknamed:The Big Red Machine
***AOL IM RiceEatinGTA***
Moderator at www.transamgta.com
"What does not kill us only makes us stronger"
Tony
Tony
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
It most definitely will not bolt up to a buick turbo motor. Those use the BOP bellhousing pattern and the T56's use the Chevy pattern. Even if you could get an adapter plate, you'd probably screw the hell out of the clutch geometry, not to mention I don't know if the flywheel will bolt to the crank (probably not).
Turbo and manaul trannies usually do not boost unless you can shift as fast as an auto tranny(some can, MOST can't). The reason i say that is, you loose alof of boost inbetween shifts.
Brendan
1987 IROC-Z L98,SuperRam,EB 6085's,LPE 219/219 Roller, Crane 1.6RR, EB TPI Base, 58mm TB, ADS 24#, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, MSD 6AL, MSD Blaster 3, Aluminum DS, 94 Disk Rear, Adjustable Valve, Precision 3.73 Gears, Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
To see the ROC, Check out the webpage Here
Brendan
Car: 2018 Camaro SS
<font face="Verdana, Arial" size="2">Originally posted by leirch:
Brendan
</font>
Brendan
</font>
88SS6SPEED
Nov 11, 2015 07:05 AM
tonys91rs
Oct 10, 2015 03:31 PM
Hello, Michael
Aug 20, 2015 03:19 PM
