Winbin editor and T-56 VSS
Old Nov 19, 2001 | 06:55 AM
'91 Formula's Avatar
Car: 1991 Firebird Formula
Engine: 383 Supercharged and Intercooled
Transmission: 6-Speed
Axle/Gears: Stock 10 bolt 3.42
Is it possible to burn a new chip with a change to the VSS settings, to adapt a T-56 VSS?
'91 Formula
383CI Superram, Sportman II's
SLP Cam 214/224 .470/.490
Vortech V1 S-Trim with custom 8 rib pullies
5-speed
3.42
12.34@117.04, 1.91 60Ft.
on Drag Radials
Old Nov 23, 2001 | 03:22 AM
crucial's Avatar
The T-56 VSS sensor is different. Besides.. you dont need to make changes in the PROM to correct for a different gear ration or different pulse. You could and maybe should if you have the equipment since the ECM does base some of its calculations on MPH, but it's not super critical. I would worry about getting my speedo to work fine first then worry about the chip.
1992 Z28 5.7 TPI
ZZ4 longblock
Harland Sharp roller rockers
Accel base and SLP siamesed runners,
52MM SLP Throttle Body
Hooker Headers & Flowmaster catback
MSD6A ignition
aluminum driveshaft
World Class 5-speed
Old Nov 23, 2001 | 06:20 PM
hectorsn's Avatar
Car: 78 Regal
Engine: 82 FBod LG4 305, 730 ECM
Transmission: M20
Axle/Gears: 4.10
http://www.delanet.com/~tgp/92Z28/02-730-vss4T56.html
This site has what you want to know although it seems to be down right now.
Old Nov 23, 2001 | 07:02 PM
crucial's Avatar
It aint down.. the website is just not there anymore !
Old Nov 24, 2001 | 05:01 PM
hectorsn's Avatar
Car: 78 Regal
Transmission: M20
Axle/Gears: 4.10
Oh well, it was rather informative. Anyhow, I think what was done was to set the PPM count down so it would agree with the gears you have. You have to go to the particular address in the prom and change it and since every mask has it in a different place, I couldn't say where it's at. I know this has been discussed on this board before so maybe a search with "T56 VSS" might provide some help.
Old Nov 25, 2001 | 04:58 PM
AlexJH's Avatar
Engine: 5.7L V8
http://www.google.com/search?q=cache...+T56+VSS&hl=en
Google is your friend!
$750 L98
Feb 1, 2025 02:25 PM
GTAman
Jul 3, 2024 07:29 PM
InfernalVortex
Apr 20, 2021 11:31 AM
tonys91rs
Oct 10, 2015 03:31 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
