best 1/4 time with 3.08 gears or numerically lower
Old Feb 10, 2009 | 10:07 AM
pearlphoenix's Avatar
Car: 86 Trans Am
Engine: 383
Transmission: Probuilt 700r4
Axle/Gears: 2.77 BW 9 Bolt
im curious to see what some 1/4 mile times are with "bad" rear end gears. im just wrapping up my build and i might have to use my 9 bolt with 2.77s for at least one more summer unless i find a great deal on a 4th gen rear this summer.
Old Feb 10, 2009 | 06:33 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: best 1/4 time with 3.08 gears or numerically lower
I ran high 11's with 3.27 gears.
Old Feb 10, 2009 | 10:36 PM
Car: 86 Trans Am
Engine: 383
do you think 11's are possible on 2.77's with an AFR headed 383
Old Feb 10, 2009 | 11:04 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Depends on the whole combination of parts but unlikely unless you're using NOS. My engine was making 500-550 HP. My high 11 second pass was at 118 MPH. A typical 12.0 run should be around 106-108 MPH. The car was a slug off the line but had huge top end power. It started getting into the camshaft powerband just before the 1000' mark.
A gear change to 4.10 and going from 26" to 28" tall tires got me into the low to mid 11's because it was geared so much better. You need deep gears to get the engine into it's powerband quicker. If it struggles down low because of a highway gear, it doesn't have enough track length to use the full potential of the powerband.
On the other hand, you could easily use a mile or 2 of highway and get to 150+ MPH with high HP and shallow gears.
Old Feb 11, 2009 | 09:31 AM
Car: 86 Trans Am
Engine: 383
im running a probuilt 700r4, 3000 stall, cam is a 537/540 with dur at 500 240/246, afr 195 eliminators and a miniram. i know i will greatly benifit from steeper gears but i want to see what i can get out of what i all ready have, last time in previous cars i hated playing the traction game with 4.11's.
Old Feb 11, 2009 | 09:36 PM
TheBigJ's Avatar
Car: 85 Firebird
Engine: SBC 383/88BW
Transmission: Built 700R4
Axle/Gears: Moser 9in/3.55
SD eh? they had some 4th gen deals going early last year at some shops around town, cheap but they were used.
Old Feb 11, 2009 | 10:28 PM
Car: 86 Trans Am
Engine: 383
yeah good ol SD, i never seen another person on here from sioux falls before. good to know lol
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
italiano67
Dec 11, 2016 09:21 AM
draco
Oct 4, 2015 09:25 PM
knight72
Aug 10, 2015 09:32 PM
