700R4 mounts
Old May 16, 2001 | 05:07 PM
ChevyGuy87's Avatar
Car: 2004 Wrangler Rubicon
Engine: 4.0
Transmission: NV3550
Axle/Gears: Dana 44s with 4.10 and air lockers
700R4 mounts
one of the mounts on my transmission busted the other day. my question is, can i replace it with the transmission in the car, or do i have to take it out?
Old May 16, 2001 | 06:27 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
You can replace it while the transmission is under the car. Here are some steps to follow:
1. Raise vehicle until you are able to slide under the vehicle. Best to have all wheels off the ground and use a reliable jack stand.
2. Use a jack and place it under the rear of the tranny. Raise jack until snug with tranny.
3. Unbolt all bolts holding the cross member to the chassis.
3. Proceed to remove worn out tranny mount. I suggest using a ploy urethane mount.
Old May 16, 2001 | 09:15 PM
ChevyGuy87's Avatar
Engine: 4.0
should i loosen the engine mounts before i jack it up?
Old May 16, 2001 | 11:22 PM
86z/92rs's Avatar
I hope you are referring to the tranny mount and if so, you could losen the tranny mount prior to raising the jack until it meets with the tranny. Just to make it clear, all your doing with the jack is to support the tranny when you remove the cross member. You shouldn't have to raise the tranny at all.
Old Feb 18, 2003 | 11:27 PM
Aerodragon911's Avatar
Where can I get on of these Poly mounts you guys are always talking about?
Hotrodboba400
Dec 10, 2019 07:07 PM
FormulasOnly
Sep 6, 2015 10:42 AM
SG91camaro
Sep 5, 2015 10:27 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
