700R4 swap from an '86 to an '88
Old Feb 10, 2009 | 02:59 PM
netfreak's Avatar
Car: 88 firebird
Engine: 305 TBI
So I've got a hookup for a free 700R4 out of an '86 firebird with more than likely a 305 under the hood (its 8 cylinder for sure). My '88, also a 305, has a blown 700R4 so I'm looking to swap. I didn't see anything definitive on the subject so I'm wondering if the trans from the '86 will hook up to the driveshaft without any issue? Also, any other compatibility issues I need to know about?
Old Feb 10, 2009 | 06:08 PM
IROC212's Avatar
Car: 1986 IROC
Engine: 355 Tpi
Axle/Gears: 9 Bolt 3.27
Re: 700R4 swap from an '86 to an '88
It should be a direct swap, only difference may be the speedo housing. It's held in with one bolt and pops out.
Old Feb 10, 2009 | 06:25 PM
kerplunk318's Avatar
your '86 has 27 splines on the input ('89 has 30). as long as you use the torque converter from the appropriate transmission you will be fine
Old Feb 10, 2009 | 11:58 PM
ed o's Avatar
Car: 64chevelle/smokey trans am
Engine: 350 p600 pro charger/350
Transmission: 350/700r4
Axle/Gears: 3.36
the 1986 might also be a "30" spline..... not a 27!, it depends on the build date. checking the input shaft will tell, not a definate 27. might be able to re-use your torque converter if it worked and the 86 is a 30 spline.
I've rebuilt many many 30 spline 86's without the aux. valvebody......etc.
Old Feb 11, 2009 | 02:44 AM
netfreak's Avatar
Car: 88 firebird
Engine: 305 TBI
Since the whole car will be mine I'll just grab the entire setup to be on the safe side. Thx for the input
Old Apr 1, 2009 | 12:30 PM
netfreak's Avatar
Car: 88 firebird
Engine: 305 TBI
As a followup, does anyone have any good links for a transmission remove/install howto? I've recently discovered the power of cinder blocks for safely raising my car on my slightly slanted driveway, and will be swapping this myself. I've got a haynes manual somewhere but I'm sure it'll be more along the "step one, remove transmission. step two, put new one in" lines...
camaro11j
Sep 19, 2018 08:49 AM
C409
Sep 1, 2015 03:42 PM
Eric-86sc
Aug 24, 2015 09:01 PM
spaigo
Aug 21, 2015 07:46 PM
TreDeClaw
Aug 14, 2015 06:58 PM
