700r4 help, please!!!!
Old May 13, 2001 | 06:10 AM
kwikgta's Avatar
I bought a the rebuild kit from pro-built awhile back and had the trans rebuilt by a local guy that is supposed to be the best trans guy in the area.I also bought a 3500 lockup stall from Darrell Young.I finally got a day off yesterday and installed the trans & converter back in the car.
If I leave the shifter in OD position it will go thru all of the gears without a problem,but if I put the shifter in low, it WILL NOT shift out manually when I move it into 2nd,3rd 0r OD.I am going t call the guy that rebuilt it tonight,but I woul like to have insight and opinions from you guys.
I am stumped,please help.
92 GTA(only 226 made)ort matched sportsman heads with 2.05 valves,64 cc,milled .015,.028 head gaskets,port matched Accel SuperRam & runners,port matched edelbrock lower intake,flow matched injectors,Fluidamper(lightweight aluminum version),jet hot headers and 2.5" mandrel bent exhaust,Random Tech. 3" cat back,underdrive pulleys,slp cam,1.6 rockers,slp cold air induction,52mm throttlebody,performance resource custom chip,Dyna module,Screamin Demon coil,Pro built 700r4 with a 10" 3500 lockup stall,3.42 posi with welded axle tubes,Zexel Torsen HD diff.,Summit rearend girdle,solid pinion spacer,& alloy axles.Boxed panhard bar,lakewood lca's & edelbrock strut tower brace,Jeg's torque arm,Jegs welded in subframe connecters.Performance friction pads,turbo slotted front rotors,stainless braid brake lines.Roh ZT 17x8.5 front wheels with 255/40ZR/17 tires. 17x9.5 rear wheels with 275/40ZR/17's.
Old May 14, 2001 | 11:37 AM
kwikgta's Avatar
Anybody?
Old May 14, 2001 | 12:08 PM
Vortex_89rs's Avatar
Does it ever shift out, just delayed, or will it absolutely never shift?
Vman
1969 Camaro Sport Coupe
383, 700R4, leather, everything black but the lights
Previous owner of an 89 RS Camaro
2.8L V6, 700R4
Old May 14, 2001 | 04:38 PM
kwikgta's Avatar
I took it all the way to 5500 rpm & it did not shift.I think maybe something is installed wrong in the valvebody,what else could it be?
It shifts great by itself,I just can't shift it manually??
Old May 14, 2001 | 07:08 PM
Pro Built Automatics's Avatar
When it is in the drive position and you do a WOT shift from 1st to 2nd, at what rpm is the shift happening at? This may tell me what the problem might be. Do you happen to know which governor you have? Let me know and I will get back to you asap.
Old May 14, 2001 | 08:54 PM
Jza's Avatar
Jza
Check the TV cable, too. It's either that or the gov.
Old May 15, 2001 | 06:03 AM
kwikgta's Avatar
Hi Dana,I have no idea what governor is in it. I know this sounds dumb but I didn't pay much attention to the rpm it shifted at wot,The car has had the trans. out since last Sept. and I was so excited to be driving it again.I will drive it again this weekend and get back to you.Hopefully with your help I can get this sorted out.
Old May 17, 2001 | 05:59 AM
kwikgta's Avatar
Dana, at WOT it shifts at 5500 rpm.What do you thinks?
Old May 17, 2001 | 06:22 AM
If it shifts at 5,500 rpm at WOT, then moving the lever earlier than 5,500 rpm while in first gear, it will not shift until that rpm is attained. You cannot overide governor below the WOT shift point. If you want to do this (override governor) you will have to install a heavier governor than you have now.
Nothing is wrong, you will have to change governor if you want different results.
Hope This Helps!!!
Old May 17, 2001 | 10:25 AM
kwikgta's Avatar
Thanks Dana! I believe I will leave it alone,5500 is agood shift point on my car.
BTW thanks for the help,and your rebuild kit was excellent!
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
