T-5 to T-56 Tranny
Old May 16, 2001 | 10:30 AM
Remnant's Avatar
T-5 to T-56 Tranny
Will I need to get a new drive shaft when I swap out the the T5 for a T56? Is the length different?
Thanks for everyones help.
Old May 16, 2001 | 01:42 PM
87RS402's Avatar
If you use the spohn kit you will only need to have your DS shortened by 2 inches.
Old May 16, 2001 | 01:50 PM
Remnant's Avatar
<font face="Verdana, Arial" size="2">Originally posted by 87RS402:
If you use the spohn kit you will only need to have your DS shortened by 2 inches.</font>
What and where do I find a Spohn Kit? I don't mind having to cut the driveshaft. My only fear is the vibration again from a poor cut. And won't the cut make the shaft weaker? Have any price estimates for a cut?
Thanks....
Old May 16, 2001 | 01:56 PM
87RS402's Avatar
Let's see...Where to find the spohn kit?
Look at the top of this page, on the right, DO you see that little "Spohn performance" banner. click on that and you will be magicly transported to his site. From there you can purchase his swap kit.
If you need the DS shortened make sure you take it to a shop that specializes in driveshafts. They should be able to make it as good as new or better.
Old May 16, 2001 | 02:49 PM
Remnant's Avatar
O.K. MR. RS! I hear ya LoUd an' ClEAR!!! What do you recommend. Gutting a 93-97 or getting an aftermarket T56? I can get a gutted t56 cheap and I was told the gear ratios in it are better then the aftermarket t56. Then again the aftermarket is pretty much a bolt on.
Anyone have an opinion?
Thanks.....
Old May 16, 2001 | 03:06 PM
87RS402's Avatar
If you can get a 93-97 for a good price then that is the route I would suggest. At $2300 for a new one I'm thinking they could keep it.
Oh, I was just teasing before. We've all been in a hurry and not looked around. But with these goofballs you need to be prepared for some good natured ribbing.
Welcome to the boards!
Old May 16, 2001 | 03:15 PM
Remnant's Avatar
No skin off my nose. That is what I was thinking... gutting a 4th gen. Do you know if the gear ratios are different between the two? I have had two people tell me they are. But I don't now earthly idea why they would be.
Old May 16, 2001 | 09:18 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
http://www.skulte.com/T56.html
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old May 17, 2001 | 02:44 AM
jaretz28's Avatar
The best T56 to use is the 1993 close ratio. In 1993 they made a wide ratio and a close ratio. This means that with the close ratio, when you shift you won't lose major RPM's so you win more races! You would sit and smoke with a wide ratio in first gear, the as you shifted to second the car feels like it bogs compared to first gear.
T-5 bellhousing to tailshaft tip 25 "
T-56 bellhousing to tailshaft tip 26 3/8 "
Old May 17, 2001 | 11:52 AM
3RDGENFRANK's Avatar
Car: 1992 Camaro Z28
Engine: 406
Axle/Gears: 4.10 GM 7.5 10-bolt
Since when do you have to shorten your driveshaft to install a T56? I've done the swap and used the stock driveshaft. My car was originally an auto, but the steel or alumunim driveshafts in auto or manual third and fourth-gen cars are all the same length and interchangeable. I don't know anyone who had to shorten the driveshaft and I personally know at least three people who have done the swap and multiple others on this board and they have all used stock drive shafts. Somebody correct me if I'm wrong. The '93 trans has a 2.97 first gear (if I remember correctly) while the '94-up T56's have a 2.66 first gear. The '93 trans is rated at 400 ft-lbs and the '94-up are rated at 450 ft-lbs. I bought my '96 T56 for $600 with 10,000 miles on it. I bought another with 70,000 miles for $650. There are good deals out there, you just have to find them.
1992 Camaro Z28; Engine:383 w/Ported Edelbrock RPM heads. Lunati Solid Roller Cam 224/232 .502/.502, Fluidampr, Comp Cams 1.5 Roller rockers and lifters, Comp Cams Triple Valvesprings, SVO 30 lb injectors. Holley/Walbro 255 lph in-tank pump, Haltech E6GM DFI, SLP 1 3/4" headers, 4" Mufflex, T56, SLP Clutch, Pro-5.0 Shifter, 4.10 Gear, Auburn Offroad Pro Posi. Super Ram. 17" X 9.5" Ronal FireHawk Rims w/ 275 40ZR17 Bridgestone RE 730's up front and Nitto Drag NT 555R's out back.
Double-Pump This! EFI Rules!
Old May 17, 2001 | 01:07 PM
Remnant's Avatar
So then the 93 does have a different first gear!! If I want a little more performance I should go with the 93 then huh??
The aftermarket T56 has a longer tailhousing, moving the mount, torque
arm, and driveshaft 1.9" rearwards. The OEM T56 (with the OEM clutch and
bellhousing) has the same exact rear dimension for the torque arm and
driveshaft, so you can reuse the parts. I hope this clarifies things.
Old May 17, 2001 | 01:37 PM
Remnant's Avatar
Is the overdrive gear in the T56 lower/smaller then in the T5? The T5 I have is greared as follows:
1st 2.95
2nd 1.94
3rd 1.34
4th 1.00
5th 0.63
Old May 17, 2001 | 01:49 PM
FormulaJoe's Avatar
Yes, 6th gear is .5 in the 94 and up T56.
L98, 3.27 9-bolt, Hooker shorty headers, custom 2.5inch Y-pipe, no cat, 3inch 2chamber flowmaster, JET AFPR, Ported MAF, Best ET: 13.86 @100mph. 1.99 60'
17 inch ROH "ZS" wheels. 17x8.5(front) and 17x9.5 (rear). Firestone Firehawk SZ50s. 245/45/zr17s and 275/40/zr17s. T56
On the way... Radar Blue 89 Formula, T56, Ram Jet 430, Ram Air, 17inch ROHs.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
tonys91rs
Oct 10, 2015 03:31 PM
bjpotter
Oct 4, 2015 07:48 PM
DARKmj16
Sep 9, 2015 04:07 PM
Formula_88AE
Sep 3, 2015 01:47 PM
