trans wont go in gear
Old May 17, 2001 | 09:52 PM
RedRS91's Avatar
if you got a 5 speed and you are trying to downshift and recently it wont go into 2nd unless you go to a different gear and go back, what kind of problem is happening?like it totally wont go into gear
Old May 17, 2001 | 10:16 PM
82z's Avatar
82z
So you are saying that if you wanted to go 3-2 you have to move the shifter to 4 or 1 then into 1? What happens when you upshift in to 2? It sounds like a cashed blocker ring but that can't be if your upshifts are ok.
82 z28 350cid, vortec heads, comp 262h cam, Holley 600cfm carb, 2in twice pipes, MSD ignition, turbo 350 trans, 3.73 posi, manly b&m megashifter
eightsixseven
Dec 16, 2024 01:50 PM
Jlanz55
Aug 17, 2015 07:15 AM
mizz0313
Aug 12, 2015 06:45 AM
dhonda200
Aug 11, 2015 11:50 PM
