Transmition replacment/rebuild
Old May 13, 2001 | 03:33 PM
talon95's Avatar
Car: 1982 Z28
Transmission: 4 Speed Manual
I’ve just acquired an ‘84 Z28 with a blown 4 speed manual transmission. A colleague has informed me that they where notoriously delicate and that I should replace it with an newer 5 speed. Is this true ?
I plan on upgrading the engine (possibly replacing the 305 with a 350). How should this affect my options ?
Old May 17, 2001 | 10:46 PM
82z's Avatar
82z
The saginaw 4 speeds are a weak suck compared to the t-5. Make sure to get a wc t-5 if you plan on going the 350 route other wise a stock replacement 85+ non-wc trans will work fine. I can't say for sure if your crossmember and driveshaft will work with a t-5. I'd say a junkyard t-5 'shaft and crossmember from a later car will work.
82 z28 350cid, vortec heads, comp 262h cam, Holley 600cfm carb, 2in twice pipes, MSD ignition, turbo 350 trans, 3.73 posi, manly b&m megashifter
Old Nov 8, 2003 | 07:17 AM
RevvedRS's Avatar
Car: '89 RS
Engine: stock(for now)
Transmission: stock (for now)
I was under the impresion that you didn't have to change the driveshaft for a 700r4/t-5( or t56) conversion. Oh well I have an entire t-5 car for parts so I don't see it being that much of a problem.
spekbikes
Jul 27, 2004 05:08 PM
mike1986fyrbird
Feb 17, 2003 03:09 AM
Stuart Moss
Dec 23, 2000 06:37 PM
82taGODD
Oct 19, 2000 01:36 PM
