TC question and help
Old May 20, 2001 | 10:47 AM
WHITE87GTA's Avatar
i am in the need for a TC but i do not want to upgrade to a high performance one at this time. i was woundering if there was a difference from a corvette TC and the one that is used on the 700r4 . my car is a 1987 L98. are there anyother gm TC that can be used as well and what one would be best suited untill i am ready for a high perf one. thanks in advance. only mods on this engine are just the simple free mods.
Old May 20, 2001 | 01:03 PM
transfixleo's Avatar
The Vette converter is a little looser than a run of the mill 700 but nothing extreme. Probably a good choice if you can get one easily. When you are ready for a converter I suggest you call Continental Converters in Ca.
Old May 20, 2001 | 10:29 PM
WHITE87GTA's Avatar
could you explain what you mean by "looser"
is this a good thing or bad?
Old May 21, 2001 | 03:46 AM
Looser means a higher stall while tighter is lower. For most somewhat modified small blocks it will work fine.
fasteddi
Sep 10, 2015 09:32 AM
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
