Rear end swap help
Old Feb 14, 2009 | 04:48 PM
91-355's Avatar
Car: 1991 Camaro
Engine: Carb'd Vortec 355
Transmission: Bowtie 700R4
Rear end swap help
I have a 91 camaro with a non-posi drum rear, I found a posi disc out of a 87 trans am on craigslist, how hard is it to swap/ would i need to buy any extra parts for the change?
Old Feb 14, 2009 | 06:08 PM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Re: Rear end swap help
Its not all that hard. It is mostly a direct swap. You will probably need the Disk brake E-brake bracket (piece up in the tranny tunnel) and you will need the disk/disk proportioning valve. Either that or get an adjustable proportioning valve. Thats what i installed instead of the factory prop valve.
Old Feb 14, 2009 | 07:00 PM
91-355's Avatar
Car: 1991 Camaro
Minus the e-brake which I dont have, all I would really need is a proportioning valve? If thats the case im picking that rear end up ASAP.
Old Feb 14, 2009 | 07:04 PM
subroc's Avatar
Engine: 355 TPI
Yup thats all u would need.
Old Feb 14, 2009 | 07:14 PM
91-355's Avatar
Car: 1991 Camaro
Thanks brother, hopefully soon ill put up a vid smoking both them eagles!
Old Feb 15, 2009 | 08:07 PM
jb3829's Avatar
Car: 1991 RS
Engine: 383 stroker
Axle/Gears: 3.23 posi
I'm in the process with a posi rear out of an 84Z. One thing to consider is you might want to change those rear brakes cause they stink. 82-88 rear disk brakes are notoriously bad. Check out the brake board for the 89-92 PBR upgrade. The upgrade is around $800. I'm accepting donations.
Old Feb 15, 2009 | 11:39 PM
subroc's Avatar
Engine: 355 TPI
800?!?! says who? You can pick up the calipers on ebay for 80ish. Backing plates are now being made by another board member for 140 or so. (forget which), and rotors are around 70 from napa. If the calipers need to be rebuilt then its 12 bucks a side. Pads are 30ish. Even if im missing something I dont get to 800.
Old Feb 16, 2009 | 12:10 AM
jb3829's Avatar
Car: 1991 RS
Engine: 383 stroker
Don't forget....ebrake cables & equalizer, hardlines + hoses (mine as well go with ss braided since your in there) & proportioning valve. Now this is based on the upgrade to the 89-92 rear system. Trust me, the 82-88 rear system is junk, they lock up all the time, I wouldn't invest in rebuilding it. Upgrade while it's off the car....it'll be much easier. Check the brake board or www.flynbye.com. Ed Miller has helped a ton of people with this. That's just my 2 cents.
hectre13
Dec 11, 2023 08:14 AM
IroczFan
Oct 6, 2015 10:13 AM
hectre13
Aug 26, 2015 08:17 AM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
