3.42 or 3.73
Old Feb 15, 2009 | 08:33 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
3.42 or 3.73
What ratio do you think would work better in my car? The car has a 305 TPI in it, bored .030 over, comp cams 260/260 adv. duration .444/.444 lift 112 LSA, Hooker 2460's and matching Y-pipe, Flowmaster 80 series, and some other small modifications as well. The car is a 5 speed also. The car has 3.73's in it now, but I was wondering if I would be better off going to 3.42's so the car will hook up better. What do you think?
Old Feb 18, 2009 | 04:37 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Re: 3.42 or 3.73
Any ideas?
Old Feb 18, 2009 | 04:43 PM
GICATA's Avatar
Car: '83 WS6 T/A 65,000 miles
Engine: 5.0L vin H stock, 406SBC right now
Axle/Gears: Corp. 3.73
Re: 3.42 or 3.73
It might hook up better with the 3.42s, and run down the road a little easier, but you will loose a little snap.
What are you looking to do with the car...drag or road?
The difference will not be tremendous, more subtle, but you will notice.
I have 3.73s and like them because it has good jump. On a long interstate drive I get tired of listening to 2,500-3,000 Rs.
Old Feb 18, 2009 | 07:23 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Re: 3.42 or 3.73
I daily drive the car but still want the "performance" for the street. I was just wondering what ratio would work better with my modifications. I've also heard a lot of people say that 3.73's are too much for TPI's because of the higher rpms.
Old Feb 18, 2009 | 07:36 PM
89rs454's Avatar
Car: 1989 SS
Engine: LT1+1500$ hooker exhaust
Axle/Gears: 3.42 bogger
Re: 3.42 or 3.73
I have 3.73s there perfect for any camaro.
Old Feb 18, 2009 | 08:38 PM
GICATA's Avatar
Re: 3.42 or 3.73
Well for snappy street perormance, you'll want the 3.73s I guess. I used to street race mine a lot and it would scoot from stop lite to stop lite real nice, but I had a bigger carb and cam than you. I always liked how easilly I could light up the tires and ****** rubber in all four gears.
Old Feb 18, 2009 | 08:49 PM
91 1LE's Avatar
Car: '91 1LE
Engine: 377 w/Stealthram
Axle/Gears: 3.42 Torsen
Re: 3.42 or 3.73
The 3.73's are your best bet. They offer more mechanical torque to make up for the 305's torque difference compared to a 350. They are also better for hooking up. With higher gears (numerically lower) once they start spinning they are harder to stop spinning (more RPM loss). You have more control with the lower gears.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
grngryoutmyway
Oct 18, 2016 05:48 PM
dbrochard
Jan 28, 2016 08:42 AM
JSDaddy189
Sep 26, 2015 03:50 PM
whyt86roc
Sep 10, 2015 10:03 PM
